[mapguide-users] RE: WMS EPSG
Bruce Dechant bruce.dechant at autodesk.com
Mon Nov 20 16:24:49 EST 2006
Brad,
You should be able to view the wms source. If you can't it could be the
extents are not where your data is or the extents are way to big. In the
later case all of your data may only appear as a point if at all if your
extents are very large.
Bruce
-----Original Message-----
Sent: November 20, 2006 2:16 PM
Subject: [mapguide-users] RE: WMS EPSG
thanks Bruce,
If our initial  map is epsg 3005 shouldn't  we be able to view wms
sources
in epsg 3005? So far we can only make a successful connection but cannot
view anything.
Bruce Dechant wrote:
> Brad,
> You will need to update the Proj.4 "epsg" file with the definition of
> EPSG:102190 and it should work. I tried to google this and couldn't
find
> it so I'm not sure what it looks like in order to test it.
> The Proj.4 file "epsg" is located by the path specified in the
> environment variable "PROJ_LIB" and you would want to add the 102190
> entry to the end of the file, ie: ..\nad\epsg
> Thanks,
> Bruce
> From: BradM [mailto:masonb at dfo-mpo.gc.ca]
> Sent: November 17, 2006 5:03 PM
> Subject: [mapguide-users] WMS EPSG
> Hi folks: simple question:  we are using BC Albers EPSG 3005 for our
> initial
> map projection.  Will  we be able to view  a WMS BC Albers map layer
> that
> uses  EPSG 102190?
> thanks
> http://www.nabble.com/WMS-EPSG-tf2657673.html#a7413308
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
http://www.nabble.com/WMS-EPSG-tf2657673.html#a7450816
More information about the Mapguide_users mailing list
