[mapguide-users] Performance Tips
Campbell, Keith A keith.campbell at atkinsglobal.com
Tue Nov 21 09:16:01 EST 2006
Thanks Andy.
I have tried base layers before and will have another look at them. I
guess there is some trade-off in that with a non-tiled map, you can zoom
to the exact location you wish to in one go, whereas with the tiled
option you may need several clicks to zoom/pan to where you want to be.
Overall it should be faster though.
Regarding image format, I think the template file is the
ajaxmappane.templ. I've tried using GIFs (which seem to give similar
quality / performance) and JPGs which produce a substandard map - unless
there is another parameter that can be fed to the mapagent, or perhaps
something more than simply 'JPG' to the FORMAT parameter, to control the
quality?
Regards,
Keith
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: 20 November 2006 18:06
Subject: RE: [mapguide-users] Performance Tips
I assume you are using the AJAX viewer.  Have you tried using Base
layers at all?  Once the tiles are created once, subsequent requests
should be faster.  This would help speed up the server side of things.
For pure bandwidth issues displaying the resultant image, you may want
to look at changing your map output format from PNG to GIF or JPG.  I
know this can be done in one of the web layout template files, but I
honestly can't remember where.  Hopefully someone else who reads this
can supply that information.
Andy
From: Campbell, Keith A [mailto:keith.campbell at atkinsglobal.com]
Sent: Monday, November 20, 2006 9:50 AM
Subject: [mapguide-users] Performance Tips
I'd be very interested to hear what people have found that have a big
impact on performance. After spending some time just working around
problem after problem to get an application ready for production, I now
find that the app may be just too slow in the clients environment to be
of any use. I can guess at a few like size of map, number of layers,
complexity and format of data sources. What is good practise? What can
be tweaked to make things faster? Can the image type (of the map) and
resolution be changed? Is one themed layer better than several filtered
layers? I realise there are hardware factors that will make a big
difference, but I'd prefer to focus on software configuration at this
point.
Keith
This email and any attached files are confidential and copyright
protected. If you are not the addressee, any dissemination of this
communication is strictly prohibited. Unless otherwise expressly agreed
in writing, nothing stated in this communication shall be legally
binding. <http://www.blackspider.com/>
This message has been scanned for viruses by MailControl
<http://bluepages.wsatkins.co.uk/?4318150>
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061121/6a09dc76/attachment.html
More information about the Mapguide_users mailing list
