[mapguide-users] Loading Packages
Stone, Matthew (DHS-HISP)
MStone at dhs.ca.gov
Tue Nov 21 14:07:02 EST 2006
Thanks Steve. It looks like the folder it was looking for was not
there, so that fixed it. Where in the documentation is the limitation
on Package size?
Matthew Stone, MPH
UCSF/CA Dept. of Health Services
Health Information & Strategic Planning (HISP)
Office of County Health Services (OCHS)
1501 Capitol Ave MS 5204
Mailing Address:
PO BOX 997413, MS 5204
Sacramento CA 95899-7413
Physical Address:
1501 Capitol Avenue, Suite 71.5195, MS 5204
Sacramento, CA 95814
_____________________________
PH: 916-552-9918
FAX: 916-552-8260
mstone at dhs.ca.gov
From: Steve Dang [mailto:steve.dang at autodesk.com]
Sent: Tuesday, November 21, 2006 10:18 AM
Subject: RE: [mapguide-users] Loading Packages
The package file size limit is 2 GB. It looks like you have no write
access to the LibraryResourceDataFilePath specified in your
serverconfig.ini file.
Steve.
From: Stone, Matthew (DHS-HISP) [mailto:MStone at dhs.ca.gov]
Sent: Tuesday, November 21, 2006 10:57 AM
Subject: [mapguide-users] Loading Packages
Anyone had luck with this? I have tried twice after creating huge
packages (almost a gig) of some shape files. When I try to load them, I
get the following errors in the log...Can anyone assist? Is there a
limit to the size?
API_NAME: LoadPackage
STATUS_CODE: Failed
PACKAGE_NAME: FromOCH1540C265R831_112006.mgp
PACKAGE_DESC: Created by ShpLoadProcedure.Execute().
PACKAGE_DATE: 2006-11-20T16:59:57
PACKAGE_SIZE: 789149912
USER_NAME: mstone
SERVER_NAME: OCH1540C265R831
SERVER_ADDR: 10.224.66.18
START_TIME: 2006-11-21T09:53:03.033875
END_TIME: 2006-11-21T09:53:05.002625
OPS_FAILED: 572
OPS_RECEIVED: 574
AVRG_OP_TIME: 984.5
ERROR_MESSAGE: A file IO exception occurred:
E:/MapguideOS/Repositories/Library/DataFiles/0ff57d0a-0000-1000-8000-000
bdb55f8ed
STACK_TRACE: - MgLibraryRepositoryManager.LoadResourcePackage line
176 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\LibraryR
epositoryManager.cpp - MgResourcePackageLoader.Start line 150 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\Resource
PackageLoader.cpp - MgResourcePackageLoader.PerformOperation line 228
file
PackageLoader.cpp - MgResourcePackageLoader.SetResourceData line 520
file
PackageLoader.cpp - MgApplicationRepositoryManager.SetResourceData line
894 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\Applicat
ionRepositoryManager.cpp - MgFileUtil.CreateDirectory line 313 file
c:\build_tux_area\mgdev_opensource\common\service\util\FileUtil.cpp
OP_DETAILS:
<2006-11-21T09:53:04.83075>
DeleteResource(Library://Data/Data/Assembly_Districts.FeatureSource)
SetResource(Library://Data/Data/Assembly_Districts.FeatureSource,Op1_SET
RESOURCE_CONTENT.xml,Op1_SETRESOURCE_HEADER.xml)
<2006-11-21T09:53:05.002625>
SetResourceData(Library://Data/Data/Assembly_Districts.FeatureSource,Ass
embly_Districts.shp,File,Op2_SETRESOURCEDATA_DATA)
Matthew Stone, MPH
Mailing Address:
Physical Address:
PH: 916-552-9918
FAX: 916-552-8260
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061121/be455cfe/attachment.html
More information about the Mapguide_users
