[mapguide-users] Loading Packages
Andy Morsell
amorsell at spatialgis.com
Tue Nov 21 14:53:58 EST 2006
Or, using unmanaged data sources in future releases should totally prevent
this problem.
Andy
_____
From: Steve Dang [mailto:steve.dang at autodesk.com]
Sent: Tuesday, November 21, 2006 11:43 AM
Subject: RE: [mapguide-users] Loading Packages
Hi Matthew,
There is no documentation on the limitation of the package size. 2 GB is the
maximum size that the server can handle. However, the Site Admin may get
timed out if the server takes too long to complete the task. So, you may
want to use smaller packages. This will be improved in the future release.
Steve.
_____
From: Stone, Matthew (DHS-HISP) [mailto:MStone at dhs.ca.gov]
Sent: Tuesday, November 21, 2006 12:07 PM
Thanks Steve. It looks like the folder it was looking for was not there, so
that fixed it. Where in the documentation is the limitation on Package
size?
Matthew Stone, MPH
UCSF/CA Dept. of Health Services
Health Information & Strategic Planning (HISP)
Office of County Health Services (OCHS)
1501 Capitol Ave MS 5204
Mailing Address:
PO BOX 997413, MS 5204
Sacramento CA 95899-7413
Physical Address:
1501 Capitol Avenue, Suite 71.5195, MS 5204
Sacramento, CA 95814
_____________________________
PH: 916-552-9918
FAX: 916-552-8260
mstone at dhs.ca.gov
_____
Sent: Tuesday, November 21, 2006 10:18 AM
The package file size limit is 2 GB. It looks like you have no write access
to the LibraryResourceDataFilePath specified in your serverconfig.ini file.
Steve.
_____
Sent: Tuesday, November 21, 2006 10:57 AM
Subject: [mapguide-users] Loading Packages
Anyone had luck with this? I have tried twice after creating huge packages
(almost a gig) of some shape files. When I try to load them, I get the
following errors in the log.Can anyone assist? Is there a limit to the
size?
API_NAME: LoadPackage
STATUS_CODE: Failed
PACKAGE_NAME: FromOCH1540C265R831_112006.mgp
PACKAGE_DESC: Created by ShpLoadProcedure.Execute().
PACKAGE_DATE: 2006-11-20T16:59:57
PACKAGE_SIZE: 789149912
USER_NAME: mstone
SERVER_NAME: OCH1540C265R831
SERVER_ADDR: 10.224.66.18
START_TIME: 2006-11-21T09:53:03.033875
END_TIME: 2006-11-21T09:53:05.002625
OPS_FAILED: 572
OPS_RECEIVED: 574
AVRG_OP_TIME: 984.5
ERROR_MESSAGE: A file IO exception occurred:
E:/MapguideOS/Repositories/Library/DataFiles/0ff57d0a-0000-1000-8000-000bdb5
5f8ed
STACK_TRACE: - MgLibraryRepositoryManager.LoadResourcePackage line 176
file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\LibraryRepos
itoryManager.cpp - MgResourcePackageLoader.Start line 150 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourcePack
ageLoader.cpp - MgResourcePackageLoader.PerformOperation line 228 file
ageLoader.cpp - MgResourcePackageLoader.SetResourceData line 520 file
ageLoader.cpp - MgApplicationRepositoryManager.SetResourceData line 894 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\ApplicationR
epositoryManager.cpp - MgFileUtil.CreateDirectory line 313 file
c:\build_tux_area\mgdev_opensource\common\service\util\FileUtil.cpp
OP_DETAILS:
<2006-11-21T09:53:04.83075>
DeleteResource(Library://Data/Data/Assembly_Districts.FeatureSource)
SetResource(Library://Data/Data/Assembly_Districts.FeatureSource,Op1_SETRESO
URCE_CONTENT.xml,Op1_SETRESOURCE_HEADER.xml)
<2006-11-21T09:53:05.002625>
SetResourceData(Library://Data/Data/Assembly_Districts.FeatureSource,Assembl
y_Districts.shp,File,Op2_SETRESOURCEDATA_DATA)
Matthew Stone, MPH
Mailing Address:
Physical Address:
PH: 916-552-9918
FAX: 916-552-8260
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061121/c1ecd20c/attachment.html
More information about the Mapguide_users
