[mapguide-users] DWF Viewer App
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue Nov 21 17:37:02 EST 2006
Seems like the right thing to do then is to have the DWF Viewer surround also go to the server to find the correct extent to zoom to.
-----Original Message-----
From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
Sent: Tue 11/21/2006 10:39 PM
Cc:
Subject: Re: [mapguide-users] DWF Viewer App
I had thought there was an artifact for it (which is why I didn't add it
myself)...but I dont' see it.
Andrew
Alain Lebatard wrote:
> The reason for the DWF search problem is that the viewer surround uses
> the DWF viewer API to select or zoom to a feature, but the viewer only
> knows about the features that are in the visible extent of the map.
> The AJAX viewer doesn’t have this problem because since it virtually
> doesn’t know anything about the features displayed, it has to
> systematically go to the server to perform selection or zoom.
> I remember that bug from before MapGuide shipped. We probably didn’t
> fix it then for lack of time, but I think there is an artifact logged
> for it.
> Alain
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Tuesday, November 21, 2006 12:46 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] DWF Viewer App
> I mainly use the DWF viewer (still not a fan of the AJAX one...I miss
> the quick panning and zooming with my mouse wheel too much!), but my
> app supports both (the user is sent to the right one according to a
> browser check)...I don't know about searching offline, but I can
> certainly tell you that you can search dwf features just the same. I'm
> using the search tool from MapGuide Studio.
> It works fine, except for 1 serious bug.....Say you're zoomed in so
> that not all features of your map are visible (some are outside your
> extents)...If you then search for features, you'll get a list. Click
> on the item you want, and you're supposed to be taken to that feature
> (the map is meant to center on that feature)......in dwf viewer, this
> wouldn't work. It ONLY works in the dwf viewer if the thing that you
> clicked on (from the list) is already on the screen somewhere.
> If you can live with this bug, then likely all you have to do is
> modify your URL. I've done almost all of my project with MapGuide
> Studio, and have set it up to work with either viewer....all I have to
> do to switch viewers is to change "mapviewerdwf" in my url to
> "mapviewerajax".
> Hope that helps!
> Andrew
> Chris Tallman wrote:
> I know the DWF Viewer app is not very popular right now because it
> requires an install. However, we are working on an app for EMS in
> vehicle mapping. I need to be able to search for an address in the DWF
> map while its disconnected from the internet or network. Has anyone
> messed with this? Is it even possible to search features in the DWF
> Map? I have a feature source that has the addresses, and I've written
> an app to search the map if I'm using the AJAX viewer, now I need that
> same functionality in the DWF viewer. If anyone has an idea on how to
> do this I am all ears.
> Thanks,
> **Chris Tallman**
> 260.356.9074
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061121/bd455b5d/attachment.bin
More information about the Mapguide_users
