[mapguide-users] a FDO building problem
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Thu Nov 23 08:08:03 EST 2006
I remember running into this once - it's been fixed in the meantime.
Open build.bat and make sure the line that has the "start_build" label
has a colon.  The line should be ":start_build".  You might run into the
same problem with build_thirdparty.bat.
Walt
-----Original Message-----
Sent: Thursday, November 23, 2006 1:58 PM
Subject: [mapguide-users] a FDO building problem
Hello all
I tried building FDO. It didn't build at all. The problem is the
build.bat
under fdo folder. It stopped because the label "start_build" Not found.
Can anyone point me towards finding the cause of this problem?
Thanks
zz
View this message in context:
http://www.nabble.com/a-FDO-building-problem-tf2692399.html#a7507920
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
