[mapguide-users] a FDO building problem
Greg Boone
greg.boone at autodesk.com
Thu Nov 23 10:08:25 EST 2006
Yes, this is a known issue and has been fixed in the Subversion trunk of
FDO.
Greg
-----Original Message-----
Sent: Thursday, November 23, 2006 8:08 AM
Subject: RE: [mapguide-users] a FDO building problem
I remember running into this once - it's been fixed in the meantime.
Open build.bat and make sure the line that has the "start_build" label
has a colon. The line should be ":start_build". You might run into the
same problem with build_thirdparty.bat.
Walt
Sent: Thursday, November 23, 2006 1:58 PM
Subject: [mapguide-users] a FDO building problem
Hello all
I tried building FDO. It didn't build at all. The problem is the
build.bat
under fdo folder. It stopped because the label "start_build" Not found.
Can anyone point me towards finding the cause of this problem?
Thanks
zz
View this message in context:
http://www.nabble.com/a-FDO-building-problem-tf2692399.html#a7507920
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
