[mapguide-users] MapGuide Studio and DXF / DWG problems....
Gord McKenzie gord.mckenzie at canam.com
Fri Nov 24 12:18:26 EST 2006
That may be the case although I cannot say for sure as we have been trying
Mapguide Open source since the pre-release of everything so it may have been
on other machines but perhaps not.
That said, what registry keys would need to be cleaned up?  I tried to clean
up the registry after my big uninstall but it was obviously not enough.  I
would hate to have to reset my entire machine.
-----Original Message-----
From: Dave Wilson [mailto:dave.wilson at autodesk.com]
Sent: Friday, November 24, 2006 10:09 AM
Subject: RE: [mapguide-users] MapGuide Studio and DXF / DWG problems....
Based on earlier threads from Bill D it may be related to registry
entries and items from earlier versions.
On the other machines did you have any previews installed or just the
release stuff? I suspect that on the working machines you never had any
Studio previews installed.
Dave
From: Gord McKenzie [mailto:gord.mckenzie at canam.com]
Sent: Friday, November 24, 2006 10:07 AM
Mapguide was first in my case and no I don't run them at the same time.
I have uninstalled Map2007 and studio and then re-installed Studio with
no change in results.
When I run Studio I watch the status line and it goes through the entire
load sequence and after loading managedmapapi it says opening test.dwg
and immediately gives the dbx cas4 4 error.
I can see the load sequence happening on a machine that works and it is
the same sequence.
Sent: Friday, November 24, 2006 10:01 AM
Which product was installed first? I assume MapGuide was last?
You aren't running both apps at the same time are you? You can only run
1 MapGuide instance when doing DWG imports because of the underlying
Autocad engine that is loaded. That would imply you can't run Map or
Civil at the same time either. If it's not a runtime problem then it has
to be DLL's.
Dave
Sent: Friday, November 24, 2006 9:57 AM
Andrew,
Sorry I misread your post a little.  The 2d/3d issue is not with DXF it
is with DWF.  I was having a problem with both but the DWF was just the
3d issue.
I have AutoCAD Map 3d 2007 on my machine.  However, I have tried it
successfully on other machines that have the same version of the
software and it works fine.
There is definitely something strange going on here because you are the
third person I know who has this issue.  Not sure how Autodesk resolves
it if they cannot reproduce the problem.
From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
Sent: Thursday, November 23, 2006 8:12 PM
Subject: Re: [mapguide-users] MapGuide Studio and DXF / DWG problems....
After posting here, I did think to go check the Autodesk groups and saw
your post (with no solution). I don't see why they're be any 3D info in
my dxf, but I'll give it another shot tomorrow and make sure it's 2D
only.
As for the version, this has happened with all versions available from
the Autodesk website. Currently I'm using the latest one with SP1......I
should also note that I've got AutoCAD Land Desktop and Civil 3D
installed on my PC.....conflicting dll's sounds to me like a pretty
logical problem.....the only question is how to fix it!
Andrew
Gord McKenzie wrote:
> I have the same issue and error.  If you look on the Mapguide
> newsgroups on the Autodesk news server, you will see I have posted to
> separate messages about this problemThe first time Bill Dhimitri tried
> to give some helpful suggestions but they did not work.  The second
> time I asked, after applying SP1, I got no replies.  I have had this
> problem on my notebook since day 1.  I have a client who purchased
> Studio and they have the same problem.  I have tried installing the
> Studio software on a couple of other machines in the office and it has
> worked fine for DWG data.  The drawings are not the issue as I can use
> the same DWG on one machine and it works but not on another.  There is
> something amiss here but no luck so far from Autodesk.  .  General
> Autodesk knowledge base alludes to this being an ARX/DLL conflict or
> version error of some sort.
> FYI, I found that if you have a 2d DWF you can work with it in Studio.
> If it is a 3d DWF it will not work.
> So far I cannot find anything to answer the problem.
> *From:* Dave Wilson [mailto:dave.wilson at autodesk.com]
> *Sent:* Thursday, November 23, 2006 2:18 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* RE: [mapguide-users] MapGuide Studio and DXF / DWG
problems....
> MapGuide Studio will allow you to import DWG files and convert them
> either to SDF or DWF. If you have a sample DWG and DXF that generates
> this error could you attach it? Maybe change the extension on the
> files to ensure they won't get filtered out by email. I'm not 100%
> sure on the DXF files.
> What version of Studio do you currently have?
> Dave
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Thursday, November 23, 2006 1:20 PM
> *Subject:* [mapguide-users] MapGuide Studio and DXF / DWG problems....
> Has anyone been able to import DXF or DWG files using MapGuide Studio
> (any version)? No matter what version of Studio (this happened in all
> of the demo versions) I use, and no matter what dxf or dwg file I try
> to bring in, I always get a fatal error msgbox that pops up and says
> "DBX CAS 4".....useful. You would think, being an Autodesk product,
> that Studio would actually be able to bring in AutoCAD files in some
> form, rather than just DWFs.....anyone else get this to work?
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
