[mapguide-users] about the version of bison
    Greg Boone
    greg.boone at autodesk.com
    Mon Nov 27 09:41:24 EST 2006
FDO does not support Bison 2.1. I recommend you install Bison 1.875 as
the build documentation states.
NOTE: The requirement to compile the yyXXX.cpp files has been removed
from FDO 3.2. In 3.2, compiling the yyXXX.cpp files is only required if
they are modified. A build script has been provided to facilitate the
build process.
Greg
-----Original Message-----
Sent: Monday, November 27, 2006 9:13 AM
Subject: [mapguide-users] about the version of bison
Hi all
When I built FDO , errors appeared as follws:
.\src\geometry\Parse\yyAwktWin.cpp(1038) : error C2143: syntax error :
missing ';' before '->'
.\src\geometry\Parse\yyAwktWin.cpp(1038) : error C2082: redefinition of
formal parameter 'pParse'
.\src\geometry\Parse\yyAwktWin.cpp(1042) : error C2143: syntax error :
.\src\geometry\Parse\yyAwktWin.cpp(1042) : error C2082: redefinition of
the corresponding program code is as follows:
short int *pParse->gis_awkt_yyssp;
GIS_AWKT_YYSTYPE *pParse->gis_awkt_yyvsp;
I use Bision 2.1 to build FDO, however, OpenSourceBuild__README.txt
tells
that FDO has been tested using Bison 1.875. Is the errors caused by the
version of bision?  Can anyone point me towards finding the cause of
this
problem?
thanks
zz
View this message in context:
http://www.nabble.com/about-the-version-of-bison-tf2711945.html#a7560611
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
