[mapguide-users] Syntax
Stone, Matthew (DHS-HISP) MStone at dhs.ca.gov
Tue Nov 28 17:35:00 EST 2006
I guess what I was hoping is that there was a little more than basic
operands for numeric data, and concatenation for string data.  It would
be good to have a rounding function to get rid of trailing decimals or
0's and it would be good to be able to use parsing string functions
(such as left(), or right() etc.).  If these are available, I don't see
them.
Matthew Stone, MPH
UCSF/CA Dept. of Health Services
Health Information & Strategic Planning (HISP)
Office of County Health Services (OCHS)
1501 Capitol Ave MS 5204
Mailing Address:
PO BOX 997413, MS 5204
Sacramento CA 95899-7413
Physical Address:
1501 Capitol Avenue, Suite 71.5195, MS 5204
Sacramento, CA 95814
_____________________________
PH: 916-552-9918
FAX: 916-552-8260
mstone at dhs.ca.gov
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Monday, November 27, 2006 7:14 PM
Subject: RE: [mapguide-users] Syntax
Currently, no mathematical functions are supported for theming
expressions. It is easy enough to add simple math functions
(sin/cos/etc) to the expression engine -- which ones do you need? I know
there are plans to extend it anyway...
 For layer filters, what functions are supported depends on the
underlying FDO provider.
Traian
	-----Original Message-----
	From: Stone, Matthew (DHS-HISP) [mailto:MStone at dhs.ca.gov]
	Sent: Mon 11/27/2006 7:21 PM
	Cc:
	Subject: [mapguide-users] Syntax
	Is there a complete list of the syntax options available in the
Expression Builder for layers?  Right now, I am doing things by trial
and error, but would like to be able to do more mathematical functions
to a field value....is that possible?  The help page is minimal at
best...
	Matt
	Matthew Stone, MPH
	Mailing Address:
	Physical Address:
	PH: 916-552-9918
	FAX: 916-552-8260
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061128/9dd067bc/attachment.html
More information about the Mapguide_users mailing list
