GetSelectionXML() how to read <Class id='Default:xxx'> in PHP.
Maciej Skorczewski maciej.skorczewski at procad.pl
Thu Nov 30 14:11:44 EST 2006
hi good people!
i work on 2 layer, all are selectable and visible on map, all object on
any of this 2 layer have a data (name,id, etc).
when user click on object it is selected , so i can get xml of this
selection...so i get it.
First selected  object on  layer "test" ganerate this XML
<FeatureSet>
<Layer id="376274-234-234-234-23-4234">
<Class id="Default:test">
<ID>BQAAAA==</ID>
</Layer>
</FeatureSet>
First selected  object on  layer "test2" ganerate this XML
<FeatureSet>
<Class id="Default:test2">
<ID>BQAAAA==</ID>
</Layer>
</FeatureSet>
question is how can i get form this 2 xml , name of cliked layer
<Class id="Default:test"> --> layer: test
..i second
<Class id="Default:test2"> --> layer: test2
if  have name of layer i can read (id,name , etc.)of selected
object.that is what i want.
is there any MG API solution? or i must use ex. SimpleXML to work whit
this xml.
...the best way mayby in future
$layer_name=$object->GetLayerName($xml_of_selected_object);
Maciej
More information about the Mapguide_users mailing list
