[mapguide-users] SetFilter filter function exceptions with sdf
Zak James
zak4ms at gmail.com
Mon Oct 2 10:16:45 EDT 2006
D'oh!
Thanks, Jack. I thought I had tried that but I guess not. In defense
of my error, all the examples in the Web Api documentation use all
lower case names for functions.
The other thing I found is that to use the function in a computed
property, you have to
use SelectAggregate - it will still throw the exception if you try to
use SelectFeatures. I originally thought using SelectAggregate was
pointless with SDF as the provider doesn't support grouping.
zak
On 10/1/06, Jack Lee <jack.lee at autodesk.com> wrote:
> Hi Zak,
> The function names are case sensitive. You should change "max(FeatId)" to "Max(FeatId)".
> -----Original Message-----
> From: Zak James [mailto:zak4ms at gmail.com]
> Sent: Sun 10/1/2006 9:29 PM
> To: users at mapguide.osgeo.org
> Cc:
> Subject: [mapguide-users] SetFilter filter function exceptions with sdf
> Hi,
> Has anyone had any problems using the built in filter functions for
> the OSGeo.SDF.3.1 provider via the Mapguide 1.0.1 api?
> The capabilities show they are supported but I get the following
> exception when trying to use them to filter a Select operation:
> An exception occurred in FDO component.
> Function not supported
> - MgFeatureServiceHandler.ProcessOperation line 83 file
> c:\build_tux_area\mgdev_opensource\server\src\services\feature\FeatureServiceHandler.cpp
> - MgOpSelectFeaturesSpatial.Execute line 115 file
> c:\build_tux_area\mgdev_opensource\server\src\services\feature\OpSelectFeaturesSpatial.cpp
> - MgServerSelectFeatures.SelectFeatures line 217 file
> c:\build_tux_area\mgdev_opensource\server\src\services\feature\ServerSelectFeatures.cpp
> Hopefully I'm just doing something stupid. Here's the php code:
> $queryOptions = new MgFeatureQueryOptions();
> $queryOptions->AddComputedProperty("MyMax", "max(FeatId)");
> $featureClass = $layer->GetFeatureClassName();
> $featureReader = $featureService->SelectFeatures($featureSourceId,
> $featureClass, $queryOptions);
> The featuresourceid points to a session feature source which
> references a valid sdf file. I've also tried going the SelectAggregate
> route and I've tried other functions listed in the sdf capabilities
> xml with similar results.
> zak
> Zak James
> Applications and Software Development
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
Zak James
More information about the Mapguide_users
