Digitizing and Redlining ...sample code.
Maciej Skorczewski maciej.skorczewski at procad.pl
Wed Oct 4 09:11:01 EDT 2006
hi all!
I get x,y coorinates from user who cliked on map (he can add new point
to map like Hotels, Pubs etc.)
then i send it into php script (code below)
It works but not to end:
PROBLEMS:
1. New marker-symbol point is not in cliked point (it is upper-right
above my x,y coorinates)
2. when i want add another marker-symbol , the old disappears (so it is
still one marker)
So what is wrong whit this.
Can anybody help me?
Maciek
// coordiantes of cliked point of map (user can add new point to map)
// it comes form javascript ,
$x=$_GET['x'];
$y=$_GET['y'];
require_once 'utilityfunctions.php';
//this file come form sample aplication Sheboygan
//so look there what is inside
require_once 'findparcelfunctions.php';
require_once('../common.php');
require_once($webExtensionsDirectory .
'www/mapviewerphp/layerdefinitionfactory.php');
try
     // Initialize
     MgInitializeWebTier($webconfigFilePath);
     $mgSessionId = ($_SERVER['REQUEST_METHOD'] ==
"POST")?$_POST['SESSION']: $_GET['SESSION'];
     $userInfo = new MgUserInformation($mgSessionId);
     $siteConnection = new MgSiteConnection();
     $siteConnection->Open($userInfo);
     $parcelMarkerFeatureSourceId = new
MgResourceIdentifier("Session:".$mgSessionId."//PropertyMarker.FeatureSource");
     $parcelMarkerCommands = new MgFeatureCommandCollection();
     $resourceService =
$siteConnection->CreateService(MgServiceType::ResourceService);
     $featureService =
$siteConnection->CreateService(MgServiceType::FeatureService);
     // Open the map
     $map = new MgMap();
     $map->Open($resourceService, 'town');
     $parcelMarkerLayer = GetLayerByName($map,'ParcelMarker');
          if ($parcelMarkerLayer == null)
             CreateParcelMarkerFeatureSource($featureService,
$parcelMarkerFeatureSourceId);
CreateParcelMarkerLayer($resourceService, $parcelMarkerFeatureSourceId,
$mgSessionId);
             $map->GetLayers()->Insert(0, $parcelMarkerLayer);
         else
             $parcelMarkerCommands->Add(new
MgDeleteFeatures('ParcelMarker', "ID like '%'"));
   //Creating the point
      $geometryFactory = new MgGeometryFactory();
      $coordinate = $geometryFactory->CreateCoordinateXY($x, $y);
      $point = $geometryFactory->CreatePoint($coordinate);
   //Define a property collection
   $geometryReaderWriter = new MgAgfReaderWriter();
     $properties = new MgPropertyCollection();
   $properties->Add(new MgStringProperty('Owner','Hotel'));
   $properties->Add(new MgGeometryProperty('Location',
$geometryReaderWriter->Write($point)));
   //Create an insert command for this property.
   $parcelMarkerCommands->Add(new MgInsertFeatures('ParcelMarker',
$properties));
     // If the parcel command set is non empty, then call the
   // UpdateFeatures method to apply the commands to the
   // temporary feature source. Then ensure the Parcel Marker
   // Layer is visible and force a refresh.
   if ($parcelMarkerCommands->GetCount() > 0)
          $featureService->UpdateFeatures($parcelMarkerFeatureSourceId,
$parcelMarkerCommands, false);
          $parcelMarkerLayer->SetVisible(true);
          //$parcelMarkerLayer->ForceRefresh();
          $sessionIdName = "Session:$mgSessionId//town.Map";
          $sessionResourceID = new MgResourceIdentifier($sessionIdName);
          $sessionResourceID->Validate();
          $map->Save($resourceService, $sessionResourceID);
          $mapUpdated = false;
        else
         echo '';
catch (MgException $e)
     echo "<script language=\"javascript\" type=\"text/javascript\"> \n";
     echo "    alert(\" " . $e->GetMessage() . " \"); \n";
     echo "</script> \n";
Maciej Skorczewski
More information about the Mapguide_users mailing list
