[mapguide-users] SQL Server 2005
Lockyer James
James.Lockyer at bradford.nhs.uk
Wed Oct 4 10:09:29 EDT 2006
Cheers,
Can I ask why it has taken three months to point that out or why this is not mentioned in the any of the help files/ published material on the internet or for that matter why the UK resellers are unaware of this fact. And is there any intention of creating an effective FDO for SQL.
In case you have X,Y,Z coordinates stored in different columns, the ODBC provider should be used against SQL Server data. - has this been speeded up in the latest release? As when I tried this it took over 40 minutes to map out four points.
Has anyone thought about using GML as a storage mechanism?
Jim
James Lockyer
GIS Specialist
IM&T
Bradford and Airedale Teaching PCT
New Mill, Victoria Road, Saltaire, Shipley, West Yorkshire, BD18 3LD
Tel: 01274 366031
This email is intended for the use of the addressee only and may contain confidential information, copyright material or views/opinions that do not necessarily reflect those of the organisation. If you receive this email by mistake please advise the sender immediately. All should be aware that this email may be subject to public disclosure under the Freedom of Information Act 2000 and that emails are monitored periodically.
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: Wed 04/10/2006 14:39
Subject: RE: [mapguide-users] SQL Server 2005
The SQL Server provider is intented to work with datastore created with Map 3D 2007 inside SQL Server 2000 and 2005.
It has it's own geometry storage and spatial indexing mechanism. Although it could reverse engineer existing database, this would be done for non-spatial data only as it has no mean to identify geometry property in the database.
Just wanted to make sure the provider was not being used for what it was not design for.
RF
From: Lockyer James [mailto:James.Lockyer at bradford.nhs.uk]
Sent: Wednesday, October 04, 2006 2:59 AM
Supported yes - does it work... now that's the question.
From: Gord McKenzie [mailto:gord.mckenzie at canam.com]
Sent: Tue 03/10/2006 22:04
Thanks
From: Warren Medernach [mailto:warren.medernach at imaginit.ca]
Sent: Tuesday, October 03, 2006 1:33 PM
Hello Gord,
I was informed by the ADN that the FDO provider supports: SQL Server 2000 (SP4) and SQL Server 2005.
Warren Medernach
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061004/3a40f6d1/attachment.bin
More information about the Mapguide_users
