[mapguide-users] SQL Server 2005
Jason Birch Jason.Birch at nanaimo.ca
Wed Oct 4 15:50:25 EDT 2006
I'm wondering if the C++ or .Net APIs for FDO provide enough functionality that someone could create FDO data stores / schemas without the use of Map 3D?
Jason
From: Lockyer James [mailto:James.Lockyer at bradford.nhs.uk]
Sent: Wed 2006-10-04 8:37 AM
Subject: RE: [mapguide-users] SQL Server 2005
Hi Robert
Thanks for that, I read some of the documents but none stated that the FDO SQL only worked if you had Map 3D - it was something I guessed by accident when I was trying to reverse engineer the process of connection.  So effective FDO to me would mean one that didn't rely on me purchasing a third software package.
What information is there about FGF binary format? I've managed to create an SQL file which sorts out the meta data on the SQL file.  I'd stopped when I established that the expected datasource was in fact binary rather than GML (which was my firt thought as to how data could be stored).
Jim
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061004/e081218b/attachment.bin
More information about the Mapguide_users mailing list
