[mapguide-users] SQL Server 2005
Orest Halustchak orest.halustchak at autodesk.com
Wed Oct 4 16:54:29 EDT 2006
Hi Jason,
Yes, there are APIs that you can use. FdoICreateDatastore will create a
new FDO datastore via the API. You can define new schema using the FDO
schema related API's.
Orest.
  _____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, October 04, 2006 3:50 PM
Subject: RE: [mapguide-users] SQL Server 2005
I'm wondering if the C++ or .Net APIs for FDO provide enough
functionality that someone could create FDO data stores / schemas
without the use of Map 3D?
Jason
  _____
From: Lockyer James [mailto:James.Lockyer at bradford.nhs.uk]
Sent: Wed 2006-10-04 8:37 AM
Hi Robert
Thanks for that, I read some of the documents but none stated that the
FDO SQL only worked if you had Map 3D - it was something I guessed by
accident when I was trying to reverse engineer the process of
connection.  So effective FDO to me would mean one that didn't rely on
me purchasing a third software package.
What information is there about FGF binary format? I've managed to
create an SQL file which sorts out the meta data on the SQL file.  I'd
stopped when I established that the expected datasource was in fact
binary rather than GML (which was my firt thought as to how data could
be stored).
Jim
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061004/655d5eb1/attachment.html
More information about the Mapguide_users mailing list
