[mapguide-users] Does Mapguide support unicode?
Traian Stanev
traian.stanev at autodesk.com
Tue Oct 10 09:40:57 EDT 2006
As long as you set the correct font for the labeling and that font is
available on the client system (if using the DWF viewer) then non-ascii
labels should work. If using the AJAX viewer, you need to have the Hindi
font installed on the server, because the server does the rendering.
Luckily, the Hindi script goes left to right, which is the only way the
server rendering can handle.
Traian
_____
From: shailesh [mailto:shailesh at simplexindia.com]
Sent: Tuesday, October 10, 2006 12:32 AM
Subject: [mapguide-users] Does Mapguide support unicode?
Hi all,
Can we display mapgude labels any other language other the english
We would be using Map 3d to create maps and store them in oracle spatial
. The attributes of the parcels and lots are to be stored in our
national language - Hindi.
Is mapguide capable to dislaying the labels in any other langauge other
than english,
If it supports unicoce then i think it must be possible , Has someone
already implemented this ? can some one guide me ?
Thanks
Shailesh
--------------------------------------------------------------------- To
unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061010/975eb7e8/attachment.html
More information about the Mapguide_users
