[mapguide-users] mapguide open source in an disconnected environment
Robert Bray
rbray at robertbray.net
Thu Oct 12 17:36:23 EDT 2006
Jorge,
Depends heavily on the requirements of your disconnected client. One
approach is as you mention, to generate EPlot DWF files for use in the
DWF Viewer in the disconnected client. Another option is to run a
MapGuide Server / Web Extensions on the disconnected client. If you need
the server-side capabilities, feature query, geometric analysis, etc
then the second approach is the way to go. MapGuide is pretty
lightweight and works well in a disconnected environment like this.
Bob
Jorge Loureiro - GIS wrote:
> What do we have to do so that it is possible to use mapguide open
> source in an disconnected environment?
> It will be generating an Eplot of our map that will be worked in our
> application using dwf viewer, or there is another way to do this?
> Thanks in advance,
> Jorge Loureiro
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
