[mapguide-users] multiline labels
Tom Fukushima
tom.fukushima at autodesk.com
Thu Oct 12 19:44:12 EDT 2006
Here is a link to the defect entry in Project Tracker
https://mapguide.osgeo.org/servlets/Scarab?id=MG349
in case you would like to follow its status.
_____
Sent: Thursday, October 12, 2006 5:23 PM
Subject: RE: [mapguide-users] multiline labels
This is a known defect with the AJAX Viewer. Multi-line labels are
handled correctly if you use DWF Viewer.
_____
From: Knight, Gregory [mailto:Gregory.Knight.bra at cityofboston.gov]
Sent: Friday, October 13, 2006 1:11 AM
Subject: [mapguide-users] multiline labels
Hi all,
I have some a field associated with a feature source that I am using as
labels. Some of these fields would display better on multiple lines. I
have tried replicating the label field in my feature source and adding
new line characters (\n) where I would like the line breaks. However,
these characters dont result in a line break and just get output along
with the rest of the label contents.
If it makes a difference, I am using MapGuide in a the c# .net
environment with the ajax viewer. Are multiline labels supported?
Thanks,
Greg
_____
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061012/dcd30c39/attachment.html
More information about the Mapguide_users
