[mapguide-users] Tolerance for selection
Chris Tallman ctallman at innomap.com
Fri Oct 13 07:00:49 EDT 2006
I have found that if you use an image like a png the point selection is
much better.  I think it uses the image bounds at the selection area.
If you stick to the MG default symbols its almost impossible to select a
point.
You have to create a symbol library and add your images to said library.
When you are setting up your point layers you can select any image in
the symbol library.
Hope this helps.
Chris
-----Original Message-----
Sent: Friday, October 13, 2006 3:54 AM
Subject: RE: [mapguide-users] Tolerance for selection
I have had this problem too, especially with symbols. Im 6.5 the you
could select the entire symbol by clicking on it, in mgOS you must
exactly click on the insertion point.
I wrote my own selection tool, which uses a selectRadius with a radius
of 3 meters so the symbol is selected...
Willem
-----Oorspronkelijk bericht-----
Van: Jim O'Leary [mailto:joleary.public at gmail.com]
Verzonden: donderdag 12 oktober 2006 20:07
Aan: users at mapguide.osgeo.org
Onderwerp: [mapguide-users] Tolerance for selection
Can you change the tolerance for selecting points? The Select tool
doesn't
always select a point. Any tips for making this tool work better?
Thanks
View this message in context:
http://www.nabble.com/Tolerance-for-selection-tf2432048.html#a6781554
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
