[mapguide-users] RE: Am i on the Right Track?
Andy Morsell
amorsell at spatialgis.com
Sat Oct 14 11:20:11 EDT 2006
That's right, I had forgotten. Andrew DeMerchant put a PHP script together
that would do this:
https://mapguide.osgeo.org/servlets/ReadMsg?listName=users
<https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=1877>
&msgNo=1877
Andy
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Friday, October 13, 2006 11:44 PM
Subject: [mapguide-users] RE: Am i on the Right Track?
Didn't somebody post a code example here that did this in a generic way?
Darned if I can remember when or who...
Jason
_____
Sent: Fri 2006-10-13 10:29 PM
Subject: [mapguide-users] RE: SPAM-LOW: [mapguide-users] RE: Am i on the
Right Track?
That code was developed, in part, for a client and I do not have the
authority to give away the source code. I can tell you the rough coding
steps:
-Grab the selection XML
-Query the original feature source using the feature ID's from the selection
XML using the FDO API
-Retrieve from the query results the key that makes sense to you and your
data
-Pass your key values to your external report
-Your external report then queries the pertinent database tables to produce
the final report
Andy
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061014/d850e1be/winmail.bin
More information about the Mapguide_users
