[mapguide-users] Add to point some properties (name,key).How? take a look on code.
Farah farah at egovernments.org
Tue Oct 17 06:36:14 EDT 2006
To understand the xml more, use  your mapguide studio to save any layer (
with all the required settings) as xml and go though that xml code.
To save a layer as xml: open the layer. Then you have an option in the file
menu: Save as xml.
farah
-----Original Message-----
From: Maciej Skorczewski [mailto:maciej.skorczewski at procad.pl]
Sent: Tuesday, October 17, 2006 3:47 PM
Subject: Re: [mapguide-users] Add to point some properties (name,key).How?
Where can i find complex manual about configure xml file? Who is used to
  create point.
this i may xml.
<LayerDefinition version="1.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="LayerDefinition-1.0.0.xsd">
   <VectorLayerDefinition>
     <ResourceId></ResourceId>
     <FeatureName>Puby</FeatureName>
     <FeatureNameType>FeatureClass</FeatureNameType>
     <Geometry>SHPGEOM</Geometry>
     <VectorScaleRange>
       <MaxScale>225560566</MaxScale>
       <PointTypeStyle>
         <DisplayAsText>false</DisplayAsText>
         <AllowOverpost>false</AllowOverpost>
         <PointRule>
           <LegendLabel></LegendLabel>
           <Label>
             <Unit>Points</Unit>
             <SizeContext>DeviceUnits</SizeContext>
             <SizeX>7</SizeX>
             <SizeY>7</SizeY>
             <Text>Owner</Text>
             <FontName>Verdana</FontName>
             <ForegroundColor>FF000000</ForegroundColor>
             <BackgroundColor>FFFFFFFF</BackgroundColor>
             <BackgroundStyle>Ghosted</BackgroundStyle>
             <HorizontalAlignment>&apos;Right&apos;</HorizontalAlignment>
             <VerticalAlignment>&apos;Baseline&apos;</VerticalAlignment>
           </Label>
           <PointSymbolization2D>
             <W2D>
               <Unit>Millimeters</Unit>
               <SizeX>7</SizeX>
               <SizeY>7</SizeY>
               <W2DSymbol>
<ResourceId>Library://gdansk2/symbols/add.SymbolLibrary</ResourceId>
                 <LibraryItemName>PushPin2</LibraryItemName>
               </W2DSymbol>
             </W2D>
           </PointSymbolization2D>
         </PointRule>
       </PointTypeStyle>
     </VectorScaleRange>
     <VectorScaleRange>
       <PointTypeStyle>
         <PointRule>
             <W2D>
               <SizeX>7</SizeX>
               <SizeY>7</SizeY>
               <W2DSymbol>
               </W2DSymbol>
             </W2D>
         </PointRule>
       </PointTypeStyle>
     </VectorScaleRange>
   </VectorLayerDefinition>
</LayerDefinition>
Farah napisał(a):
> The properties that you want displayed in the property pane should be set
in
> your xml file:
> For ex:
> <PropertyMapping>
>             <Name>PROPERTY_ID</Name>
>             <Value>Property Id</Value>
>     </PropertyMapping>
> Regards
> farah
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
