Selection highlighting problem in version 1.0.2?
Campbell, Keith A
keith.campbell at atkinsglobal.com
Tue Oct 17 10:37:33 EDT 2006
Since installing version 2, I've noticed that when I select an object
from a layer with an ODBC feature join, all objects within the layer are
highlighted on the map. The properties panel displays the correct
information for the individual object and the correct tooltip appears
above it. Does anybody else have this problem? If so, can you confirm it
is since installing 1.0.2?
Keith
This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061017/da92a1ef/attachment.html
More information about the Mapguide_users
