[mapguide-users] ArcSDE
Brad Nesom kidsmake6 at msn.com
Tue Oct 17 13:00:51 EDT 2006
You should probably check with ESRI, but as I understand it you can now in
9.1 use unlimited sde connections from an esri software. If you use direct
connectons then you have a limited number of sde connections. Unless I am
mistaken the ArcSDE FDO is ESRI software. If someone knows different that
would be the killing point.
Brad
-----Original Message-----
From: Brian Flood [mailto:BFLOOD at SPATIALDATALOGIC.COM]
Sent: Tuesday, October 17, 2006 10:52 AM
To: 'users at mapguide.osgeo.org'
Subject: RE: [mapguide-users] ArcSDE
thanks Robert
I know you probably cannot answer this definitively since its an ESRI
question but if you have ArcSDE installed on your server, you should be able
to use the client libraries on the same server (or any server that connects
to that ArcSDE instance), right?
cheers
brian
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: Tuesday, October 17, 2006 11:10 AM
The ArcSDE client libs are not redistributable.  They need to come with
proper licensing from ESRI products.
RF
Sent: Tuesday, October 17, 2006 10:17 AM
thanks Orest, that was the page I was looking for.
are the sde client libraries distributable?
cheers
brian
From: Orest Halustchak [mailto:orest.halustchak at autodesk.com]
Sent: Tuesday, October 17, 2006 8:32 AM
Hi Brian,
Yes, the source code for the ArcSDE provider is available as open source
(https://fdoarcsde.osgeo.org/).
It uses SDE client libraries. You have to make sure that you have these
dll's available and in your path: sde91.dll, sg91.dll, and pe91.dll. It
does not currently support raster, but it does support versioned
databases through the FDO long transaction versioning commands.
Thanks,
Orest.
Sent: Monday, October 16, 2006 3:26 PM
Subject: [mapguide-users] ArcSDE
hello all
 a few questions on the ArcSDE SDO for Oracle/SQLServer
1) Is the source code available as part of the free community download?
If
no, any pointers on where to find out about Enterprise?
2) Does it use native SQL communication or does it rely on the SDEClient
libraries provided by ESRI?
3) How's the performance when compared to other SDE access layers? How
about
ESRI tools?
4) Does it have Raster support?
5) Long shot - does it work with Versioned geodatabases? (e.g. delta
tables)
cheers
brian
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
