[mapguide-users] Selection highlighting problem in version 1.0.2?
Jonathon McIntyre
jm at pat.ca
Tue Oct 17 17:36:48 EDT 2006
I have found this to be a problem also since installing 1.0.2. By
removing the ODBC join, I can get individual selections again.
Jonathon
From: Campbell, Keith A [mailto:keith.campbell at atkinsglobal.com]
Sent: Tuesday, October 17, 2006 7:38 AM
Subject: [mapguide-users] Selection highlighting problem in version
1.0.2?
Since installing version 2, I've noticed that when I select an object
from a layer with an ODBC feature join, all objects within the layer are
highlighted on the map. The properties panel displays the correct
information for the individual object and the correct tooltip appears
above it. Does anybody else have this problem? If so, can you confirm it
is since installing 1.0.2?
Keith
This email and any attached files are confidential and copyright
protected. If you are not the addressee, any dissemination of this
communication is strictly prohibited. Unless otherwise expressly agreed
in writing, nothing stated in this communication shall be legally
binding. <http://www.blackspider.com/>
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061017/4630f52f/attachment.html
More information about the Mapguide_users
