[mapguide-users] RE: RE: PHP version
Jason Birch Jason.Birch at nanaimo.ca
Wed Oct 18 11:08:25 EDT 2006
The first links (the tar files) are source code.  You need to install
the executable packages which are a bit further down the list.
If you can't log into the administrator, then there's definitely
something wrong with your installation.  Let us know when you get the
old version uninstalled and 1.0.2 installed.  In your case, you will
likely want to choose IIS integration.
Jason
-----Original Message-----
Sent: Wednesday, October 18, 2006 02:12
Subject: [mapguide-users] RE: RE: PHP version
Hi Jason,
I guess I have install the old version of mapguide. first of all sorry
if I am troubling you. can I know the step of installing the opensource
1.0.2?I download tar file for that. but I am confused in how to install
it.
currently I am using windows server 2003. I am not able to log in into
map administrator, where it didnt show anything only blank page.and I am
trying to view the shebboygan map but it shows nothing. I am looking
forward for your reply.
Regards,
Kencana
Jason Birch wrote:
> It's difficult to troubleshoot your problems with the level of details
> you're providing.
> What version of MapGuide are you trying to install?  I would suggest
> starting with MapGuide Open Source 1.0.2, as it has a much cleaner
> installation than any of the earlier versions.  Either that or waiting
> for the SP1 from Autodesk.  There are known issues with some locales
> in earlier versions of MapGuide.
> What operating system are you running?
> Are you able to login to the Map Administrator?
> Are you able to login to mapguide/mapagent/index.html and get a value
> for the EnumerateResources query?
> Where are you unable to see the map?  In Studio?  In the sample
> application?
> What data are you looking at?  Sheboygan?  Your own data?
> Is there any other information you can provide that could help with
> the resolution of this problem?
> Jason
> ________________________________
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Tue 2006-10-17 11:40 PM
> Subject: [mapguide-users] RE: PHP version
> Hi Jason,
> Thanks for the reply. I have try to install mapguide 2007 with IIS>PHP
> config.
> But when i try to view the map it shows nothing. I have follow the
> installation instruction bt still nothing.
> I hope you can give me solution. I am looking forward for your reply
> and thank you.
> Regards,
> Kencana
> Jason Birch wrote:
>> MapGuide Open Source (and I believe Enterprise) are reliant on PHP
>> version 5.0.5.
>> At least, that was the case last time I checked (several users have
>> found this out by running with newer unsupported versions of PHP) and
>> PHP 5.0.5 is the version which is bundled with MapGuide.
>> Jason
>> Sent: Tue 2006-10-17 9:35 PM
>> Subject: [mapguide-users] PHP version
>> Hi guys,
>> I am new to this "Autodesk Mapguide 2007" and I want to ask about the
>> php version which compatible to this software. I am looking forward
>> for the reply and thank you very much.
>> Regards,
>> Kencana
>> View this message in context:
>> http://www.nabble.com/PHP-version-tf2464139.html#a6869321
>> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> http://www.nabble.com/PHP-version-tf2464139.html#a6870320
http://www.nabble.com/PHP-version-tf2464139.html#a6872289
More information about the Mapguide_users mailing list
