Fail 'Load Package' from 1.0.1 to 1.0.2
Jose Manuel C G gis at mapas-sll.com
Wed Oct 18 11:33:45 EDT 2006
When I try to 'Load Package' from 1.0.1 (win or linux) to 1.0.2, the package
FAIL and get the next error on the page:
An exception occurred in DB XML component. Error: XML Indexer: Parse error
in document at line, 7, char 31. Parser message: Datatype error:
Type:InvalidDatatypeFacetException, Message: Invalid chars encountered..
The log show:
API_NAME:	LoadPackage
STATUS_CODE:	Failed
PACKAGE_NAME:	21017.mgp
PACKAGE_DESC:
PACKAGE_DATE:	2006-10-18T17:22:36
PACKAGE_SIZE:	330736
USER_NAME:	Administrator
SERVER_NAME:	vmwarepruebas
SERVER_ADDR:	172.16.0.24
START_TIME:	2006-10-18T17:28:13.15625
END_TIME:	2006-10-18T17:28:13.890625
OPS_FAILED:	9
OPS_RECEIVED:	34
AVRG_OP_TIME:	29.359999999999999
ERROR_MESSAGE:	An exception occurred in DB XML component. Error: XML
Indexer:  Parse error in document at line, 7, char 31. Parser message:
Datatype error: Type:InvalidDatatypeFacetException, Message: Invalid chars
encountered..
STACK_TRACE:	- MgLibraryRepositoryManager.LoadResourcePackage line 176 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\LibraryRepositoryManager.cpp
- MgResourcePackageLoader.Start line 150 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourcePackageLoader.cpp
- MgResourcePackageLoader.PerformOperation line 228 file
- MgResourcePackageLoader.SetResource line 308 file
- MgRepositoryManager.SetResource line 867 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\RepositoryManager.cpp
- MgRepositoryManager.AddResource line 840 file
- MgResourceContentManager.AddResource line 183 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourceContentManager.cpp
- MgResourceContentManager.PutDocument line 654 file
- MgResourceDefinitionManager.PutDocument line 554 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourceDefinitionManager.cpp
OP_DETAILS:
<2006-10-18T17:28:13.171875>
SetResource(Library://Andevalo/21017/,,Library/Andevalo/21017/_HEADER.xml)
<2006-10-18T17:28:13.203125>
SetResource(Library://Andevalo/21017/Data/,,Library/Andevalo/21017/Data/_HEADER.xml)
<2006-10-18T17:28:13.21875>
SetResource(Library://Andevalo/21017/Layers/,,Library/Andevalo/21017/Layers/_HEADER.xml)
<2006-10-18T17:28:13.234375>
SetResource(Library://Andevalo/21017/Maps/,,Library/Andevalo/21017/Maps/_HEADER.xml)
<2006-10-18T17:28:13.25>
SetResource(Library://Andevalo/21017/Layouts/,,Library/Andevalo/21017/Layouts/_HEADER.xml)
<2006-10-18T17:28:13.265625>
DeleteResource(Library://Andevalo/21017/Data/21017u_Manzanas-urb-pol.FeatureSource)
<2006-10-18T17:28:13.28125>
SetResource(Library://Andevalo/21017/Data/21017u_Manzanas-urb-pol.FeatureSource,Library/Andevalo/21017/Data/21017u_Manzanas-urb-pol.FeatureSource_CONTENT.xml,Library/Andevalo/21017/Data/21017u_Manzanas-urb-pol.FeatureSource_HEADER.xml)
<2006-10-18T17:28:13.3125>
SetResourceData(Library://Andevalo/21017/Data/21017u_Manzanas-urb-pol.FeatureSource,21017u_Manzanas-urb-pol.sdf,File,Library/Andevalo/21017/Data/21017u_Manzanas-urb-pol.FeatureSource_DATA_21017u_Manzanas-urb-pol.sdf)
<2006-10-18T17:28:13.40625>
DeleteResource(Library://Andevalo/21017/Data/21017u_nombres_calles-urb-txt.FeatureSource)
<2006-10-18T17:28:13.421875>
SetResource(Library://Andevalo/21017/Data/21017u_nombres_calles-urb-txt.FeatureSource,Library/Andevalo/21017/Data/21017u_nombres_calles-urb-txt.FeatureSource_CONTENT.xml,Library/Andevalo/21017/Data/21017u_nombres_calles-urb-txt.FeatureSource_HEADER.xml)
<2006-10-18T17:28:13.453125>
SetResourceData(Library://Andevalo/21017/Data/21017u_nombres_calles-urb-txt.FeatureSource,21017u_nombres_calles-urb-txt.sdf,File,Library/Andevalo/21017/Data/21017u_nombres_calles-urb-txt.FeatureSource_DATA_21017u_nombres_calles-urb-txt.sdf)
<2006-10-18T17:28:13.46875>
DeleteResource(Library://Andevalo/21017/Data/21017u_num_policia-urb-txt.FeatureSource)
SetResource(Library://Andevalo/21017/Data/21017u_num_policia-urb-txt.FeatureSource,Library/Andevalo/21017/Data/21017u_num_policia-urb-txt.FeatureSource_CONTENT.xml,Library/Andevalo/21017/Data/21017u_num_policia-urb-txt.FeatureSource_HEADER.xml)
<2006-10-18T17:28:13.5>
SetResourceData(Library://Andevalo/21017/Data/21017u_num_policia-urb-txt.FeatureSource,21017u_num_policia-urb-txt.sdf,File,Library/Andevalo/21017/Data/21017u_num_policia-urb-txt.FeatureSource_DATA_21017u_num_policia-urb-txt.sdf)
<2006-10-18T17:28:13.578125>
DeleteResource(Library://Andevalo/21017/Layers/21017u_Calles-urb-lin.LayerDefinition)
SetResource(Library://Andevalo/21017/Layers/21017u_Calles-urb-lin.LayerDefinition,Library/Andevalo/21017/Layers/21017u_Calles-urb-lin.LayerDefinition_CONTENT.xml,Library/Andevalo/21017/Layers/21017u_Calles-urb-lin.LayerDefinition_HEADER.xml)
<2006-10-18T17:28:13.625>
DeleteResource(Library://Andevalo/21017/Layers/21017u_Manzanas-urb-pol.LayerDefinition)
<2006-10-18T17:28:13.640625>
SetResource(Library://Andevalo/21017/Layers/21017u_Manzanas-urb-pol.LayerDefinition,Library/Andevalo/21017/Layers/21017u_Manzanas-urb-pol.LayerDefinition_CONTENT.xml,Library/Andevalo/21017/Layers/21017u_Manzanas-urb-pol.LayerDefinition_HEADER.xml)
<2006-10-18T17:28:13.6875>
DeleteResource(Library://Andevalo/21017/Layers/21017u_nombres_calles-urb-txt.LayerDefinition)
SetResource(Library://Andevalo/21017/Layers/21017u_nombres_calles-urb-txt.LayerDefinition,Library/Andevalo/21017/Layers/21017u_nombres_calles-urb-txt.LayerDefinition_CONTENT.xml,Library/Andevalo/21017/Layers/21017u_nombres_calles-urb-txt.LayerDefinition_HEADER.xml)
<2006-10-18T17:28:13.734375>
DeleteResource(Library://Andevalo/21017/Layers/21017u_num_policia-urb-txt.LayerDefinition)
<2006-10-18T17:28:13.75>
SetResource(Library://Andevalo/21017/Layers/21017u_num_policia-urb-txt.LayerDefinition,Library/Andevalo/21017/Layers/21017u_num_policia-urb-txt.LayerDefinition_CONTENT.xml,Library/Andevalo/21017/Layers/21017u_num_policia-urb-txt.LayerDefinition_HEADER.xml)
<2006-10-18T17:28:13.796875>
DeleteResource(Library://Andevalo/21017/Layers/21017u_Parcelas-urb-pol.LayerDefinition)
SetResource(Library://Andevalo/21017/Layers/21017u_Parcelas-urb-pol.LayerDefinition,Library/Andevalo/21017/Layers/21017u_Parcelas-urb-pol.LayerDefinition_CONTENT.xml,Library/Andevalo/21017/Layers/21017u_Parcelas-urb-pol.LayerDefinition_HEADER.xml)
<2006-10-18T17:28:13.84375>
DeleteResource(Library://Andevalo/21017/Maps/Mapa.MapDefinition)
<2006-10-18T17:28:13.859375>
SetResource(Library://Andevalo/21017/Maps/Mapa.MapDefinition,Library/Andevalo/21017/Maps/Mapa.MapDefinition_CONTENT.xml,Library/Andevalo/21017/Maps/Mapa.MapDefinition_HEADER.xml)
Any idea? another bug in this release?
View this message in context: http://www.nabble.com/Fail-%27Load-Package%27-from-1.0.1-to-1.0.2-tf2467422.html#a6878936
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide_users mailing list
