new FDO King.Oracle provider 0.3
Haris Kurtagic
haris at sl-king.com
Wed Oct 18 14:41:51 EDT 2006
I have released new version of FDO King.Oracle provider.
Version 0.3.1 features:
* Added support for spatial context (coordinate systems) and layer
extent
It will report spatial context and layer extend to MapGuide.
So when you create layer it should became visible immediatly
* Added Filter and expression processing support
You can set filter when query data. It can be spatial or/and
attribute filter
* Support for all spatial query types
EnvelopeIntersect, Intersects, Contains, Crosses, Disjoint,
Overlaps, Touches,
Within, CoveredBy ,Inside ,Equals
* Added support for executing any sql commands
Using FDOISQLCommand or MgFeatureService::ExecuteSqlQuery you
can run any sql command against Oracle database. You can read/write
spatial geometries and attributes.
* Changed Conection properties names for Service and Username
Bad: Existing data connections needs to be reset
Good: Provider can be used in Autodesk Map 2007. You can use
Oracle XE with MAP
* New connection property OracleSchema
If it is empty than it will look in all Oracle Schemas for
spatial tables.
If you set this then it will look in just that schema
* Linked with new version fdo 3.1 .R70 (MG 1.0.2)
It is available at www.sl-king.com/fdooracle
Haris
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061018/b7216a38/attachment.html
More information about the Mapguide_users
