[mapguide-users] How to can make mapguide faster?
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Oct 19 16:11:53 EDT 2006
By chance are you using DWF Viewer? Base layers only have their performance benefit when using the AJAX viewer.
Also as Traian mentioned, keep the number of base layer groups to a minimum - 1 or 2. It doesn't matter how many base layers are in a group - it takes time to render the tiles initially, but once rendered the time to access is independent of the number of base layers.
Also note that tiles are rendered / cached on demand. You might have been using your tiled map for some time, but if you explore a new area of the map where there still aren't any tiles then it will initially be slow. I'm sure someone will one day post a little utility which pregenerates all tiles for a given extent / range of scales, and then this wouldn't be a problem.
Walt
-----Original Message-----
From: Maciej Skorczewski [mailto:maciej.skorczewski at procad.pl]
Sent: Thu 10/19/2006 9:36 PM
Cc:
Subject: Re: [mapguide-users] How to can make mapguide faster?
hi Traian !
my layers come from sdf file (no raster)
1.streets (whit names - they are stored in sdf files)
2.buildings (whit number- they are stored in sdf files)
3.forest
4.see water
5.lake
6.City-border
7. main-streets (whit names - they are stored in sdf files)
8. Train
in future (i work on it) user can add point to map ex. hotels,pub
but if i use zoom scale (label are show in const zoom scale) lebel
1,2,3,4,5 are no show. in you zoom 1-5 are show (no all in time)
Traian Stanev napisał(a):
> How many base layer groups do you have? The viewer would be requesting a
> separate image for each base layer group...
Maciej Skorczewski
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061019/26d46657/attachment.bin
More information about the Mapguide_users
