[mapguide-users] bad performance with mysql or sql server
Jason Birch
Jason.Birch at nanaimo.ca
Fri Oct 20 03:24:16 EDT 2006
Hi Antonio,
I'm assuming that you're using Enterprise? There is a HUGE performance difference between the rdbms drivers in MGOS 1.0.1 and 1.0.2, and I'm pretty sure that you'll see the same benefit if you upgrade your Map 3D to SP3 (read about the performance improvements in the SP readme) and your MapGuide Enterprise to SP1... when it's released. It gets more Q/A than the open source release, which is a large part of what you're paying for with Enterprise.
I believe that a lot of the changes are around FDO connection pooling and changes in the way that the schema is requested in the rdbms providers. Haris has noted that it has made a big difference for the open source King.Oracle provider.
Jason
From: SER&TEC Antonio Lucas [mailto:alucas at srtec.com]
Sent: Fri 2006-10-20 12:03 AM
Subject: [mapguide-users] bad performance with mysql or sql server
Hello,
I'm testing my project changing sdf based layers to fdo mysql or sql
server as data sources. I'm loading data from Autodesk Map 3D 2007 and
authoring with Studio but the performance is very very bad. It seems
that fdo provider for relational database works slow.
(sorry for my english...)
Thanks.
Antonio Lucas
Software Engineer
alucas at sercad.com <mailto:alucas at sercad.com> www.sercad.com
<http://www.sercad.com>
963·959·513
Fax 963·731·756
SER&TEC
avda. Ausias March 79 - 1
46013 Valencia
Este mensaje puede contener información confidencial, privilegiada o
datos de carácter personal. Si usted no es el destinatario indicado en
el mismo o el responsable de su entrega, le rogamos no copie o entregue
este mensaje a nadie más. En dicho caso, por favor, destruya este
mensaje y comunique a Sercitec Servicios Informáticos S.L. su recepción.
Las opiniones, conclusiones y demás información incluida en este mensaje
que no está relacionada con asuntos profesionales de Servitec Servicios
Informáticos S.L. se entenderá que nunca se ha dado, ni está respaldada
por Servitec Servicios Informáticos S.L.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061020/0691e5f6/attachment.bin
More information about the Mapguide_users
