FDO King.Oracle provider 0.3
Joel Carranza
jec at gatekeeper.com
Fri Oct 20 15:40:06 EDT 2006
I found the problem. There was an oracle installation (linking?) problem, and
that problem was causing problems in FDO. The GetFeatureProviders function
was returning the FDO info but without any connection properties. Very
strange.
Now I've gotten further, i'm seeing some layers to choose from. My views
still aren't showing up (even through they are setup in
USER_SDO_GEOM_METADATA) Haven't seen any actual data displayed on the map
though.
Attempting to figure things out, Get Spatial Contexts returns something a
little weird.
<SpatialContext IsActive="true">
<Name>Longitude / Latitude (NAD 83)</Name>
<Description/>
<CoordinateSystemName>Longitude / Latitude (NAD 83)</CoordinateSystemName>
<CoordinateSystemWkt>
GEOGCS [ "Longitude / Latitude (NAD 83)", DATUM ["NAD 83", SPHEROID ["GRS
80", 6378137, 298.257222101]], PRIMEM [ "Greenwich", 0.000000 ], UNIT
["Decimal Degree", 0.01745329251994330]]
</CoordinateSystemWkt>
<ExtentType>Static</ExtentType>
<Extent>
<LowerLeftCoordinate>
<X>-10000000</X>
<Y>-10000000</Y>
</LowerLeftCoordinate>
<UpperRightCoordinate>
<X>10000000</X>
<Y>10000000</Y>
</UpperRightCoordinate>
</Extent>
<XYTolerance>0.001000</XYTolerance>
<ZTolerance>0.000000</ZTolerance>
</SpatialContext>
Shouldn't this be returning something that resembles my data?
A connection to my 9.2 DB fails with
An exception occurred in FDO component. OCI-22303: type
"MDSYS"."SDO_TOPO_OBJECT" not found
Any intention to support 9.2 ?
Joel
haris kurtagic wrote:
> Are you using Autodesk MapGuide Studio - list should be easy editable in
> it :).
> Haris
> -----Original Message-----
> From: Joel Carranza [mailto:jec at gatekeeper.com]
> Sent: Friday, October 20, 2006 7:03 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] RE: FDO King.Oracle provider 0.3
> I got that. I did read the readme before I started this, I promise :)
> My problem is that I literally can't figure out how to edit the property
> list. I am sure my brain is just running slow or something. But, how do
> I specify these connection properties? Should the list be editable,
> because it isnt. Do I have to put these properties in the "configuration
> file" What is the format of that file?
>> Hi,
>> there should be four properties:
>> Username - you enter username to connect to Oracle ( oracle user you
>> created in database ) Password - password of user Service - this is
>> service name for Oracle database, depends of type of client and
>> configuration
>> for example for xe you can enter: //localhost/xe
>> or tns name if you configured it in your oracle client
> software
>> there is more in readme.txt on download page
>> OracleSchema - leave it empty and it will show all spatial tables, or
>> you enter Oracle schema name and you got tables just from that schema.
>> If I wasn't clear enough, please ask again :)
>> Haris
>> Sent: Friday, October 20, 2006 6:20 PM
>> Subject: [mapguide-users] FDO King.Oracle provider 0.3
>> I have downloaded and installed the new Open Source v1.0.2 release of
>> MapGuide, along with the King.Oracle FDO. FDO shows up in my list of
>> providers, but when I get to the "Configure Feature Resource using
>> Generic Editor" screen, I can't figure out how to specify my
>> There is a list in the window with Property/Value pairs, but I can't
>> seem to figure out how to edit that list.
>> Am I missing something obvious here?
>> Thanks
>> Joel
>> View this message in context:
>> http://www.nabble.com/FDO-King.Oracle-provider-0.3-tf2481642.html#a692
>> 01
>> 21
>> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> http://www.nabble.com/FDO-King.Oracle-provider-0.3-tf2481642.html#a69209
> 60
View this message in context: http://www.nabble.com/FDO-King.Oracle-provider-0.3-tf2481642.html#a6923839
More information about the Mapguide_users
