[mapguide-users] bad performance with mysql or sql server
Bill Tenbroeck
btenbroeck at itssg.com
Mon Oct 23 12:55:14 EDT 2006
Hey Bruce, that seems to be the case - first time is slow whether I pull it up in Studio or via a browser, and then afterwords it's fast. Currently I'm using the Ajax viewer, though easy enough to change if helpful.
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Mon 10/23/2006 11:42 AM
Subject: RE: [mapguide-users] bad performance with mysql or sql server
Bill,
When the layer takes a long period of time is it always the 1st time you load it? If you reload the layer a 2nd/3rd/etc time is it fast?
Are you using the DWF viewer or AJAX viewer?
Thanks,
Bruce
Sent: October 20, 2006 6:22 AM
I'm using SQL Server as a secondary table via ODBC. There are times when it takes 2 minutes for a layer using the secondary datasource to load and other times it loads immediately. I'm on 1.0.2. Anyone have a similar experience or thoughts?
From: SER&TEC Antonio Lucas [mailto:alucas at srtec.com]
Sent: Fri 10/20/2006 3:57 AM
Subject: Re: [mapguide-users] bad performance with mysql or sql server
Jason Birch escribió:
> Hi Antonio,
> I'm assuming that you're using Enterprise? There is a HUGE performance difference between the rdbms drivers in MGOS 1.0.1 and 1.0.2, and I'm pretty sure that you'll see the same benefit if you upgrade your Map 3D to SP3 (read about the performance improvements in the SP readme) and your MapGuide Enterprise to SP1... when it's released. It gets more Q/A than the open source release, which is a large part of what you're paying for with Enterprise.
> I believe that a lot of the changes are around FDO connection pooling and changes in the way that the schema is requested in the rdbms providers. Haris has noted that it has made a big difference for the open source King.Oracle provider.
> Jason
> Sent: Fri 2006-10-20 12:03 AM
> Subject: [mapguide-users] bad performance with mysql or sql server
> Hello,
> I'm testing my project changing sdf based layers to fdo mysql or sql
> server as data sources. I'm loading data from Autodesk Map 3D 2007 and
> authoring with Studio but the performance is very very bad. It seems
> that fdo provider for relational database works slow.
> (sorry for my english...)
> Thanks.
> Antonio Lucas
> Software Engineer
> alucas at sercad.com <mailto:alucas at sercad.com> www.sercad.com
> <http://www.sercad.com>
> 963·959·513
> Fax 963·731·756
> SER&TEC
> avda. Ausias March 79 - 1
> 46013 Valencia
> Este mensaje puede contener información confidencial, privilegiada o
> datos de carácter personal. Si usted no es el destinatario indicado en
> el mismo o el responsable de su entrega, le rogamos no copie o entregue
> este mensaje a nadie más. En dicho caso, por favor, destruya este
> mensaje y comunique a Sercitec Servicios Informáticos S.L. su recepción.
> Las opiniones, conclusiones y demás información incluida en este mensaje
> que no está relacionada con asuntos profesionales de Servitec Servicios
> Informáticos S.L. se entenderá que nunca se ha dado, ni está respaldada
> por Servitec Servicios Informáticos S.L.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
> Hi Antonio,
> Jason
> Hello,
> Thanks.
> Antonio Lucas
> Software Engineer
> 963·959·513
> Fax 963·731·756
> SER&TEC
> 46013 Valencia
Hello Jason,
Sorry, I forget to post my configuration:
- SQL Server 2005 + Autodesk Map 3D 2007 SP3 + MGE and java viewer
- Mysql 5.0 + Autodesk Map 3D 2007 SP3 + MGOS 1.0.2 and the latest mysql
fdo provider (I think R071...).
In both cases, the performance is bad in comparison with sdf based layers.
Thanks.
Antonio Lucas
Software Engineer
963·959·513
Fax 963·731·756
SER&TEC
46013 Valencia
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061023/5f14f8ab/attachment.html
More information about the Mapguide_users
