[mapguide-users] King.Oracle 0.3.2
Joel Carranza
jec at gatekeeper.com
Mon Oct 23 21:12:07 EDT 2006
Your my hero Haris,
I got datasets displaying right out of the box with this version. This
includes my Oracle 9.2 instance. I think that may be the first time that
has ever happened with this new MapGuide :) I will continue to test and
provide you with some more feedback tommorow.
The biggest issue for me is that my views still aren't being displayed.
Could this be because the spatial index is declared on the underlying table
and not on the view itself?
Joel
haris kurtagic wrote:
> Hi,
> some new features for King.Oracle 0.3.2 provider: ( wishes coming from
> people testing this provider).
> 1. Support for Oracle 9i
> I have tested querying data and schema creation on 9.2 and it works ok.
> 2. Support for Geodetic Coordinate system
> Previous release didn't work well with geodetic data.
> I run some test and it seems it is working ok now.
> Uses optimized rectangle for envelope queries, so it should work even
> for whole earth queries.
> 3. Spatial tables which have geometry column registered in
> sdo_geom_metadata with "." in name will be skipped.
> Geometry can come from function so it is registered with "." in name.
> Dot is not allowed in FDO xml schema names.
> This is temporary workaround.
> Get it here: www.sl-king.com/fdooracle
> I will soon release version with support for editing of geometries
> trough fdo provider and that would conclude my first round of features.
> I would like to ask community for suggestions/whishes what would like to
> see in this provider.
> If someone can help me in putting some kind of web survey I would
> appreciate very much.
> Is something like this possible on this ColabNet's or ..?
> Thank you,
> Haris
View this message in context: http://www.nabble.com/King.Oracle-0.3.2-tf2498546.html#a6965381
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide_users
