[mapguide-users] MapGuide 1.0.2 with Autodesk Raster FDO?
Tue Oct 24 10:05:05 EDT 2006
Federico Primon wrote:
> Hi all,
> I’ve just downloaded release 1.0.2 for Windows, along with the FDO
> Providers samples: is there an explanation about the distribution of
> Autodesk Raster Provider (3.1 R071)?
> Does it means that Autodesk will release the code to the community?
> Where can I find the code to compile GDAL Provider 3.1 R071?
Federico,
The FDO GDAL provider is available in the SVN repository of the project
at http://fdogdal.osgeo.org/
However, the provider was implemented against the development FDO API
which is FDO 3.2.  That means it is, unfortunately, not possible to use
it with FDO 3.1 applications, such as the public release of MapGuide.
I have successfully tested it with the development version of MapGuide
for those brave enough to do everything directly from SVN.
I believe Autodesk is providing use of the Autodesk Raster Provider
as a stopgap till the release MapGuide is using FDO 3.2, but it not
expecting to release the source to it.  It depends on quite a variety
of internal components I believe.
I hope this helps explain the situation a bit, even if it doesn't
accomplish anything for you in the short term.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the Mapguide_users mailing list
