[mapguide-users] Build MG open source 1.0.2 using FDO 3.1.0 R050
Ernesto Vega ernesvega at gmail.com
Tue Oct 24 14:05:45 EDT 2006
Bruce:
Finally, I decided to use FDO R071. I could eventually build FDO R071
but my problem started when building mapguide open source 1.0.2.
Just to have in mind, I'm using fedora core 5.
After running build_oem.sh, I run the make but it stopped with this error:
ChannelBand.h:77: error: explicit instantiation of 'class
std::auto_ptr<MdfModel::ChannelBand>' in namespace 'MdfModel' (which
does not enclose namespace 'std')
any ideas ??
Ernesto
On 10/23/06, Bruce Dechant <bruce.dechant at autodesk.com> wrote:
> This is not recommended at all. MG open source build 1.0.2 was built
> with FDO R071 and is designed for that version. There are several
> defects in FDO R050 that have been fixed in FDO R071 that you will not
> benefit from. Also, the MG server has had code changes made to work with
> the fixes/changes in FDO R071 that do not exist in FDO R050.
> Bruce
> -----Original Message-----
> From: Ernesto Vega [mailto:ernesvega at gmail.com]
> Sent: October 23, 2006 2:22 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] Build MG open source 1.0.2 using FDO 3.1.0
> R050
> Hi. I cannot build FDO R071, so i decided to use the R050 version to
> build MG open source 1.0.2, beacuse i cannot build FDO R071 on Fedora
> Core 5.
> Is there a problem with this solution ???
> Hope you can help on this.
> Ernesto
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
