[mapguide-users] King.Oracle 0.3.3
Paul Spencer pspencer at dmsolutions.ca
Tue Oct 24 20:47:01 EDT 2006
Several people have indicated excellent performance.  I have no
experience with Oracle so I am curious if anyone has comments on
performance relative to SDF?  Faster/slower?  Conditions under which
it is faster/slower?
Cheers
Paul
On 24-Oct-06, at 6:28 PM, Haris Kurtagic wrote:
> I am getting this after login as Anonymous:
> An unclassified exception occurred. Exception occurred in method
> MgWebLayout.ParseWebLayoutDefinition at line 294 in file c:
> \build_tux_area\mgdev\web\src\webapp\WebLayout.cpp
> Haris
> From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
> Sent: Tuesday, October 24, 2006 11:19 PM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] King.Oracle 0.3.3
> Haris:
> I’m seeing some other strange things.  The labels on some of my
> polygons have odd characters in them.  Not sure where these are
> coming from.
> http://gis.co.pinellas.fl.us/mapguide/mapviewerajax/?
> WEBLAYOUT=Library%3a%2f%2fPinellas%2fLayouts%
> 2fkingtest.WebLayout&LOCALE=en
> Use Anonymous for the user and zoom into a scale of at least 10,000
> to pull up the parcels.  Then hover over one of them.   The
> performance for these coming up is great.
> I’m just stumped on why the Evacuation Routes are not displaying
> with the parcels.  Same coordinate system in the database.  The
> layer previews fine too.  I can see them when editing the layer
> style; just can’t see them when I place the layer in the map.
> Juan Butler - Senior Programmer/Analyst
> GIS Applications
> Pinellas County Information Systems
> jpbutler at pinellascounty.org
> Please note: All mail sent to and from Pinellas County Government
> is subject to the Public Records Law of Florida.
> From: Haris Kurtagic [mailto:haris at sl-king.com]
> Sent: Tuesday, October 24, 2006 4:43 PM
> Hi Juan,
> I am looking at this memory usage.
> Which version of MG are you using ?
> Haris
> Sent: Tuesday, October 24, 2006 10:26 PM
> True…I was thinking about it.  I would just need to construct the
> GEOMETRY in the view.   I’ll try it out.
> Thanks.
> GIS Applications
> Sent: Tuesday, October 24, 2006 3:31 PM
> I would suspect it is a memory leak in provider. I will check it.
> "I just wish I could use this for non Oracle Spatial tables with
> coordinate fields" - you mean like displaying points from x,y
> columns ?
> Beside suporting it in provider, one of the ways could be to create
> a view in Oracle for it.
> Haris
> Sent: Tuesday, October 24, 2006 7:52 PM
> Haris:
> I’m testing this now and it seems that your provider is pulling up
> the spatial data much faster.  The only problem that I’m running
> into is the server process is eating up memory at a large clip when
> adding more layers from Oracle.  It’s gotten up to over a GIG.
> I’ve had to shutdown Mapguide server completely and then restart
> it.  The memory usage will go back up as I interact with more
> Oracle spatial layers.  Not sure if it’s more on the Mapguide
> server side or the provider.
> coordinate fields.  The ODBC provider will not show tables for me.
> GIS Applications
> Sent: Tuesday, October 24, 2006 7:17 AM
> Subject: [mapguide-users] King.Oracle 0.3.3
> Hi,
> newer version of King.Oracle 0.3.3 provider:
> Support for Spatial Views
> It will display views based on spatial tables. Views needs to be
> added into sdo_geom_metadata for provider to find them.
> Get it here: www.sl-king.com/fdooracle
> Haris
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the Mapguide_users mailing list
