[mapguide-users] Build MG open source 1.0.2 using FDO 3.1.0 R050
Ernesto Vega
ernesvega at gmail.com
Wed Oct 25 08:52:10 EDT 2006
Traian:
I did so. I read about it right after posting the email.
I was finally abble to build it on FC5. It took me a while but i did.
The problem is not mapguide, it has to be with gcc 4.1 being very hard
on those kinds of declarations.
thanks
Ernesto
On 10/25/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> Are you using the latest code from subversion? I remember fixing this gcc
> 4.1 build error three months ago in artifact MG339.
> Here is the diff, which should give you a hint as to how to fix it:
> https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/ChannelBand.h?r1=42&r2=722&p1=trunk/MgDev/Common/MdfModel/ChannelBand.h&p2=trunk/MgDev/Common/MdfModel/ChannelBand.h
> Traian
> -----Original Message-----
> From: Ernesto Vega [mailto:ernesvega at gmail.com]
> Sent: Tue 10/24/2006 2:05 PM
> To: users at mapguide.osgeo.org
> Cc:
> Subject: Re: [mapguide-users] Build MG open source 1.0.2 using FDO
> 3.1.0 R050
> Bruce:
> Finally, I decided to use FDO R071. I could eventually build FDO R071
> but my problem started when building mapguide open source 1.0.2.
> Just to have in mind, I'm using fedora core 5.
> After running build_oem.sh, I run the make but it stopped with this error:
> ChannelBand.h:77: error: explicit instantiation of 'class
> std::auto_ptr<MdfModel::ChannelBand>' in namespace
> 'MdfModel' (which
> does not enclose namespace 'std')
> any ideas ??
> Ernesto
> On 10/23/06, Bruce Dechant <bruce.dechant at autodesk.com> wrote:
> > This is not recommended at all. MG open source build 1.0.2 was built
> > with FDO R071 and is designed for that version. There are several
> > defects in FDO R050 that have been fixed in FDO R071 that you will not
> > benefit from. Also, the MG server has had code changes made to work with
> > the fixes/changes in FDO R071 that do not exist in FDO R050.
> > Bruce
> > Sent: October 23, 2006 2:22 PM
> > Subject: [mapguide-users] Build MG open source 1.0.2 using FDO 3.1.0
> > R050
> > Hi. I cannot build FDO R071, so i decided to use the R050 version to
> > build MG open source 1.0.2, beacuse i cannot build FDO R071 on Fedora
> > Core 5.
> > Is there a problem with this solution ???
> > Hope you can help on this.
> > Ernesto
> > To unsubscribe, e-mail:
> users-unsubscribe at mapguide.osgeo.org
> > For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
