Turning on layer from task frame
Jim O'Leary joleary.public at gmail.com
Fri Oct 27 15:51:20 EDT 2006
Is there a way to turn on a layer (that is, programmatically check the layer
in the Layers pane) from the Task frame?
I have a select box of layers in my task frame. When the user selects a
layer, I would like the same layer to be checked in the Layer pane. Right
now the user has to check the layer manually, or else the layer is not
selectable.
Thanks
View this message in context: http://www.nabble.com/Turning-on-layer-from-task-frame-tf2522746.html#a7037212
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide_users mailing list
