Turning on layer from task frame
Jim O'Leary joleary.public at gmail.com
Fri Oct 27 17:07:50 EDT 2006
I'm doing this on the server side, where $_REQUEST[layer_name] hold the layer
that the user has selected:
$trackLayer = $layers->GetItem($_REQUEST[layer_name]);
trackLayer->SetVisible(True);
$trackLayer->SetSelectable(True);
$trackLayer->SetDisplayInLegend(True);
$trackLayer->ForceRefresh();
And then on the client side, from the script frame:
parent.mapFrame.Refresh();
However, the layer does not get checked in the Layers pane, and the layer
only becomes selectable when that checkbox is checked. I don't see a
JavaScript API call for this operation. Something like
mapFrame.checkLayer(layerName,true | false)
would be useful.
Andy Morsell wrote:
> You can use the MGLayer SetVisible method.  Note that you will also have
> to
> do a client-side API refresh in order to get your map and legend to update
> accordingly.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: Jim O'Leary [mailto:joleary.public at gmail.com]
> Sent: Friday, October 27, 2006 12:51 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] Turning on layer from task frame
> Is there a way to turn on a layer (that is, programmatically check the
> layer
> in the Layers pane) from the Task frame?
> I have a select box of layers in my task frame. When the user selects a
> layer, I would like the same layer to be checked in the Layer pane. Right
> now the user has to check the layer manually, or else the layer is not
> selectable.
> Thanks
> http://www.nabble.com/Turning-on-layer-from-task-frame-tf2522746.html#a70372
> 12
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/Turning-on-layer-from-task-frame-tf2522746.html#a7038356
More information about the Mapguide_users mailing list
