[mapguide-users] Building Search based on joined fields
Warren Medernach warren.medernach at imaginit.ca
Tue Oct 31 14:44:10 EST 2006
Ok...
I have setup a VM with MGOS 1.0.2.
Created the same setup as my work machine.
Now when I create the join to SQL Server , anytime I select a single
parcel, all of the parcels are selected....
Btw, this happens regardless whether the feature class is joined to SQL
Server or an Access database...
Warren
From: Warren Medernach [mailto:warren.medernach at imaginit.ca]
Sent: Monday, October 30, 2006 2:37 PM
Subject: RE: [mapguide-users] Building Search based on joined fields
Thanks Andy,
On this particular work machine I'm using Enterprise (1.0.0.17804)
I'll set this up at home (or in a VM) and test it later on MGOS 1.0.2.
Thanks again!
Warren
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Monday, October 30, 2006 2:31 PM
I noted the same error under the same circumstances with 1.0.1 and
Enterprise.  I was hoping it was fixed in 1.0.2 (which I have not had
time to work with yet), but it looks like the bug lingers. (you are
using 1.0.2 aren't you?)
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Sent: Monday, October 30, 2006 12:20 PM
Subject: [mapguide-users] Building Search based on joined fields
Is it possible to create a search based on a value in a joined field?
I'm getting the following error when I attempt search a joined field:
An exception occurred in FDO component. Invalid identifier name '<Field
Name>'. Exception occurred in method
MgServerGwsGetFeatures.GetMgClassDefinition at line 207 in file
c:\build_tux_area\mgdev\server\src\services\feature\ServerGwsGetFeatures
.cpp
Anybody successfully getting search results from a joined field?
Thanks
Warren Medernach
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061031/d51cb216/attachment.html
More information about the Mapguide_users mailing list
