[mapguide-users] PostgreSQL 8.1 Connection String
Eric Brown
ericbrown at netxn.com
Fri Sep 1 00:30:37 EDT 2006
gotta love those 2mb screen shots.
----- Original Message -----
Sent: Thursday, August 31, 2006 9:26 PM
Subject: Re: [mapguide-users] PostgreSQL 8.1 Connection String
the screen shot is attached which i'm getting there is no option to write the connection string
On 8/29/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
The connection string you used is an OGR connection string. You can't use an OGR connection string to connect to the ODBC FDO provider.
In the OGR dialog, you write the connection string in the field for the DataSource connection property, like the instructions for using the provider say. See the attached screenshot, which should make it clearer. If you don't see the two connection properties when you open the connection editor for OGR, it means your FDO provider is installed incorrectly.
Traian
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com ]
Sent: Tuesday, August 29, 2006 7:03 AM
sorry but till now i'm getting error.
i'm using ODGEO FDO Provider For ODBC
and using connection string : PG: host=localhost user=postgres dbname=swift password=sukalyan
& I also tried the FDO Provider For OGR but i'm not finding any place to write the connection string there
there are provider ; connection properties ; user name ; password ; version ; data files ;
configuration files etc. there is no space for write connection string
Thanks
On 8/29/06, Maciej Skorczewski <maciej.skorczewski at procad.pl > wrote:
hi
Read this manual
POSTGRES
http://ogr.maptools.org/drv_pg.html
ODBC
http://ogr.maptools.org/drv_odbc.html
MYSQL
http://ogr.maptools.org/drv_mysql.html
OGR and postgres
PG: host=localhost user=postgres dbname=dbpassword=pass
sukalyan chakraborty napisał(a):
> can any body help me?
> what is the connection string should be used while i' want to use
> PostgreSQL 8.1
> using ODBC driver or may use FDO provider for OGR
> Thanks A Lot
> Have A Nice Time
> Have Fun
> Be Jolly
> Sukalyan Chakraborty
> [Software Developer]
Maciej Skorczewski
PROCAD SA - Autodesk Systems Center
www.procad.pl
Oddział Gdańsk:
TEL. 058 302 02 67, FAX 058 302 06 29
Oddział Warszawa:
TEL. 022 322 76 86, FAX 022 322 76 87
Oddział Radom:
TEL. 048 334 01 18, TEL./FAX 048 360 92 55
Oddział Poznań:
TEL. 061 864 53 33, FAX 061 864 53 32
Oddział Katowice:
TEL. 032 251 02 02, FAX 032 251 02 96
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Thanks A Lot
Have A Nice Time
Have Fun
Be Jolly
Thanks A Lot
Have A Nice Time
Have Fun
Be Jolly
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060831/c94e5c5c/attachment.html
More information about the Mapguide_users
