[mapguide-users] Raster features are not shown
    Bruce Dechant
    bruce.dechant at autodesk.com
    Fri Sep  1 15:38:59 EDT 2006
Mindaugus,
This is a know issue that has been fixed for the latest SVN “Branch”. If you build the OS from the “1.0.x” branch you will have this fix.
This will also be included with the MapGuide Enterprise SP1 release.
Bruce
  _____
From: Mindaugas Bliudžius [mailto:mindaugas at infoera.lt]
Sent: August 31, 2006 1:12 AM
Subject: [mapguide-users] Raster features are not shown
I‘m having similar problem to this topic „rasters, always rasters!“. When i try to see raster in Studio or elsewhere i get this in error.log:
Error: An exception occurred in FDO component.
        Failed to de-serialize the spatial contexts from the configuration.
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file c:\build_tux_area\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpDescribeSchemaAsXml.Execute line 110 file c:\build_tux_area\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cpp
  - MgServerDescribeSchema.DescribeSchema line 493 file c:\build_tux_area\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
  - MgServerDescribeSchema.ExecuteDescribeSchema line 189 file c:\build_tux_area\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
  - MgFdoConnectionManager.Open line 221 file c:\build_tux_area\mgdev\server\src\common\manager\FdoConnectionManager.cpp  An exception occurred in FDO component.
I launched http://localhost/mapguide/mapagent/index.html and tried DescribeSchema method of Feature Service API. And i get the same error. I called method leaving „Schema“ textbox empty, maybe there must be entered something? . Any ideas?
I‘m using Windows Server 2003 Enterprice Edition Service Pack 1 (not R2). Installed web extension using IIS and .NET as programming language (and later used typical installation option). I‘m having the same problem with MapGuide Enterprise 2007 and with MapGuide Open Source 1.0.1.
Mindaugas Bliūdžius
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060901/8f04b066/attachment.html
More information about the Mapguide_users
