[mapguide-users] MapGuide to DWF
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Sep 1 15:46:00 EDT 2006
You can generate EPlots of your map for offline use using the
GeneratePlot API in MappingService.
You can see this in action in the sample application if you choose the
"Plot as DWF" task...
  _____
From: Chris Gountanis [mailto:cgountanis at mpower-tech.com]
Sent: Friday, September 01, 2006 3:22 PM
Subject: [mapguide-users] MapGuide to DWF
Is there a way to export data from MapGuide to a format like DWF?
Chris
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060901/1186aaf5/attachment.html
More information about the Mapguide_users mailing list
