[mapguide-users] PostgreSQL 8.1 Connection String
sukalyan chakraborty chakraborty.sarkar at gmail.com
Sat Sep 2 00:54:17 EDT 2006
Sorry !
Till now unable to get the list in connection string.
I've done the restrart server & everything which u've specified.
Thanks.
On 9/1/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
>  Yes this is strange that you don't see the connection properties listed.
> Did you try restarting the MapGuide server and Studio? One thing you can
> try is to request the provider capabilities using the MapGuide html pages.
> Under FeatureService, execute a GetFeatureProviders request and check to see
> if the returned list contains the OGR provider and the correct connection
> properties  -- see the attached screenshot.
> Traian
>  *From:* sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
> *Sent:* Friday, September 01, 2006 12:47 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] PostgreSQL 8.1 Connection String
>  sorry for large attachment I was not aware of .
> Mercy
> Please Help Me
> On 9/1/06, Eric Brown <ericbrown at netxn.com> wrote:
> >  gotta love those 2mb screen shots.
> >  ----- Original Message -----
> > *From:* sukalyan chakraborty <chakraborty.sarkar at gmail.com>
> >  *Sent:* Thursday, August 31, 2006 9:26 PM
> >    the screen shot is attached which i'm getting there is no option to
> > write the connection string
> > On 8/29/06, Traian Stanev <traian.stanev at autodesk.com > wrote:
> > >  The connection string you used is an OGR connection string. You can't
> > > use an OGR connection string to connect to the ODBC FDO provider.
> > > In the OGR dialog, you write the connection string in the field for
> > > the DataSource connection property, like the instructions for using the
> > > provider say. See the attached screenshot, which should make it clearer. If
> > > you don't see the two connection properties when you open the connection
> > > editor for OGR, it means your FDO provider is installed incorrectly.
> > > Traian
> > > *From:* sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com ]
> > > *Sent:* Tuesday, August 29, 2006 7:03 AM
> > > *Subject: *Re: [mapguide-users] PostgreSQL 8.1 Connection String
> > >  sorry but till now i'm getting error.
> > > i'm using ODGEO FDO Provider For ODBC
> > > and using connection string : PG: host=localhost user=postgres
> > > dbname=swift password=sukalyan
> > > & I also tried the FDO Provider For OGR but i'm not finding any place
> > > to write the connection string there
> > > there are provider ; connection properties ; user name ; password ;
> > > version ; data files ;
> > > configuration files etc. there is no space for write connection string
> > > Thanks
> > > On 8/29/06, Maciej Skorczewski <maciej.skorczewski at procad.pl > wrote:
> > > > hi
> > > > Read this manual
> > > > POSTGRES
> > > > http://ogr.maptools.org/drv_pg.html
> > > > ODBC
> > > > http://ogr.maptools.org/drv_odbc.html
> > > > MYSQL
> > > > http://ogr.maptools.org/drv_mysql.html
> > > > OGR and postgres
> > > > PG: host=localhost user=postgres dbname=dbpassword=pass
> > > > sukalyan chakraborty napisał(a):
> > > > > can any body help me?
> > > > > what is the connection string should be used while i' want to use
> > > > > PostgreSQL 8.1
> > > > > using ODBC driver or may use FDO provider for OGR
> > > > > Thanks A Lot
> > > > > Have A Nice Time
> > > > > Have Fun
> > > > > Be Jolly
> > > > > Sukalyan Chakraborty
> > > > > [Software Developer]
> > > > Maciej Skorczewski
> > > > PROCAD SA - Autodesk Systems Center
> > > > www.procad.pl
> > > > Oddział Gdańsk:
> > > > TEL. 058 302 02 67, FAX 058 302 06 29
> > > > Oddział Warszawa:
> > > > TEL. 022 322 76 86, FAX 022 322 76 87
> > > > Oddział Radom:
> > > > TEL. 048 334 01 18, TEL./FAX 048 360 92 55
> > > > Oddział Poznań:
> > > > TEL. 061 864 53 33, FAX 061 864 53 32
> > > > Oddział Katowice:
> > > > TEL. 032 251 02 02, FAX 032 251 02 96
> > > > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > > For additional commands, e-mail: users-help at mapguide.osgeo.org
> > > Thanks A Lot
> > > Have A Nice Time
> > > Have Fun
> > > Be Jolly
> > Thanks A Lot
> > Have A Nice Time
> > Have Fun
> > Be Jolly
> Thanks A Lot
> Have A Nice Time
> Have Fun
> Be Jolly
Thanks A Lot
Have A Nice Time
Have Fun
Be Jolly
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060902/a722c56f/attachment.html
More information about the Mapguide_users mailing list
