[mapguide-users] Feature Joins
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Sep 8 04:20:21 EDT 2006
The short answer is yes.
I have no problems displaying maps/porperties when using ODBC for
secondary sources.
But, I have written a bit with Ronnie Louie form Autodesk, about
selections on such featuresets.
Ronnie can select from such a Join using my data, but I can't.
So unless, you want to select objects from the layer and read joined
feature values using the API, you should be fine.
The error message I get is:
OSGeo.MapGuide.MgFdoException: An exception occurred in FDO component.
no string resource for id <1019> -
MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_tux_area\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpSelectFeatures.Execute line 115 file
c:\build_tux_area\mgdev\server\src\services\feature\OpSelectFeatures.cpp
- MgServerSelectFeatures.SelectFeatures line 217 file
c:\build_tux_area\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
- MgServerSelectFeatures.JoinFeatures line 1008 file
Campbell, Keith A skrev:
> All,
> Can an ODBC Feature Source be used in a Feature Join (as the secondary
> feature)?
> Thanks,
> Keith
> *This email and any attached files are confidential and copyright
> protected. If you are not the addressee, any dissemination of this
> communication is strictly prohibited. Unless otherwise expressly
> agreed in writing, nothing stated in this communication shall be
> legally binding.*
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060908/c2c0d6e6/attachment.html
More information about the Mapguide_users mailing list
