login: The specified user was not found
Axel Dörr a.doerr at doerrib.de
Fri Sep 8 13:01:35 EDT 2006
Freitag, 08.09.2006
Hello List,
i have created a weblayout and can display it. Before i can see anything i have to login.
Using default user Administrator and password admin everything works fine. Using a user i created within the
MG Site Administrator it doesn't work. I get the following error:
The specified user was not found: Username Exception occurred in method MgSecurityCache.GetUserInfo at line 149 in file c:\build_tux_area\mgdev_opensource\server\src\common\manager\SecurityCache.cpp
I use MGOS 1.0.1, MS Windows Server 2000, IIS and PHP (should be 5.0.5 from the installation).
What I did in MG Site Administrator:
I created a first new group an a first new user. I put the new user in the new group. The new user is
a member of the built in group Everyone an my own group.
Like the an anonymous user the new user has no role like administrator or map author.
When i want to edit my new user there is nothing in the field Password. I expected to see at least the dots
representing the password i entered and confirmed the first time.
What I did in MG Studio, version 1.0.0.16802:
In the Site Explorer i edited the properties of the library i want to work with. In "permissions"
i added my own user group and set the permissions to read/write. The usergroup everyone
is still there.
Thanks for help!
Axel
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060908/e56f4ade/attachment.html
More information about the Mapguide_users mailing list
