Re-2: [mapguide-users] login: The specified user was not found
Axel Dörr a.doerr at doerrib.de
Mon Sep 11 11:35:46 EDT 2006
Thanks for the help! The restart of MG did it.
If i can reproduce the problem i´ll tell you.
Axel
Original Message        processed by David InfoCenter
Subject: RE: [mapguide-users] login: The specified user was not found (08-Sep-2006 23:45)
From:    Tom Fukushima <tom.fukushima at autodesk.com>
To:      mapserver_user_discussion at doerrib.de
Thanks Andy. I’m wondering if this might have something to do with being on Windows 2000.  I’m going have to get a hold of a Windows 2000 machine myself and see what happens there.  The tests that we did were on Windows XP.
Cheers
Tom
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, September 08, 2006 3:07 PM
Hi Tom,
Sorry, no, I can't remember exactly what happened in those instances.  I've installed and setup MapGuide at least 30 times now on various systems and this was something I ran into more than once.  Once I got around it, I kept moving.  I'll be sure to document it in the future.
Andy
From: Tom Fukushima [mailto:tom.fukushima at autodesk.com]
Sent: Friday, September 08, 2006 1:43 PM
Hi Andy,
If you are able to recall what steps you went through when it failed, we can track it down. And if an artifact is entered for this that will make sure that its progress can be tracked.
Hi Axel,
A couple of us here went through the steps that you provided and could not reproduce the error.  Thanks for the detailed step. I did notice that the error came up if I had used the wrong case for the user name since the authentication is case sensitive. If you can still reproduce the problem, could you enter an artifact in project tracker with the steps to reproduce?
Thanks
Tom
Sent: Friday, September 08, 2006 11:12 AM
Have you restarted the MapGuide service?  I've seen some odd things happen when adding a new user through Admin and the change not "sticking" or having to enter the information again.
Andy
Sent: Friday, September 08, 2006 10:02 AM
Subject: [mapguide-users] login: The specified user was not found
Freitag, 08.09.2006
Hello List,
i have created a weblayout and can display it. Before i can see anything i have to login.
Using default user Administrator and password admin everything works fine. Using a user i created within the
MG Site Administrator it doesn't work. I get the following error:
The specified user was not found: Username Exception occurred in method MgSecurityCache.GetUserInfo at line 149 in file c:\build_tux_area\mgdev_opensource\server\src\common\manager\SecurityCache.cpp
I use MGOS 1.0.1, MS Windows Server 2000, IIS and PHP (should be 5.0.5 from the installation).
What I did in MG Site Administrator:
I created a first new group an a first new user. I put the new user in the new group. The new user is
a member of the built in group Everyone an my own group.
Like the an anonymous user the new user has no role like administrator or map author.
When i want to edit my new user there is nothing in the field Password. I expected to see at least the dots
representing the password i entered and confirmed the first time.
What I did in MG Studio, version 1.0.0.16802:
In the Site Explorer i edited the properties of the library i want to work with. In "permissions"
i added my own user group and set the permissions to read/write. The usergroup everyone
is still there.
Thanks for help!
Axel
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060911/ed947a8c/attachment.html
More information about the Mapguide_users mailing list
