[mapguide-users] POOL:DWF or AJAX
Jason Birch
Jason.Birch at nanaimo.ca
Fri Sep 15 11:49:35 EDT 2006
Yes, that's correct. The SET is the commandline way of creating Windows EVs, but they only stay around for the current session if you set them at the command line (I think).
Here's what I have:
FDO=D:\OSGeo\FDOBuild\fdo
FDOBUILD=D:\OSGeo\FDOBuild
FDOMYSQL=C:\Program Files\MySQL\MySQL Server 5.0
FDOTHIRDPARTY=D:\OSGeo\FDOBuild\Thirdparty
FDOUTILITIES=D:\OSGeo\FDOBuild\Utilities
FDO_SVN_ROOT=D:\OSGeo\FDODev
GDAL_DATA=D:\OSGeo\MGBuild\Oem\gdal-1.3.0\data
MGBUILD=D:\OSGeo\MGBuild
NLSDIR=D:\OSGeo\FDOBuild\Thirdparty\apache\xml-xalan\c\Src\xalanc\NLS
PROJ_LIB=D:\OSGeo\MGBuild\Oem\proj-4.4.9\nad
XALANROOT=D:\OSGeo\FDOBuild\Thirdparty\apache\xml-xalan\c
XERCESCROOT=D:\OSGeo\FDOBuild\Thirdparty\apache\xml-xerces\c
You have to be careful though, because if you have the GDAL and PROJ variables set (required for the MapGuide build) I think it messes up the FDO build. It's probably best to set these at the command line. What I do, however, is something like this:
SET OLD_GDAL_DATA=%GDAL_DATA%
SET GDAL_DATA=
SET OLD_PROJ_LIB=%PROJ_LIB%
SET PROJ_LIB=
pushd %FDOBUILD%
call build.bat
popd
SET GDAL_DATA=%OLD_GDAL_DATA%
SET OLD_GDAL_DATA=
SET PROJ_LIB=%OLD_PROJ_LIB%
SET OLD_PROJ_LIB=
Jason
Sent: Friday, September 15, 2006 08:37
Subject: RE: [mapguide-users] POOL:DWF or AJAX
Ok, thanks!!!
And just one more thing...
3. Ensure that the Windows Environment Variables are set as follows:
SET FDO=[FDO OpenSource]\Fdo
SET FDOUTILITIES=[FDO OpenSource]\Utilities
SET FDOTHIRDPARTY=[FDO OpenSource]\ThirdParty
SET XALANROOT=%FDOTHIRDPARTY%\apache\xml-xalan\c
SET XERCESCROOT=%FDOTHIRDPARTY%\apache\xml-xerces\c
SET NLSDIR=%XALANROOT%\Src\xalanc\NLS
Q: What is variable and what is value? For example? Is FDO variable and [FDO OpenSource]\Fdo value? Is that correct?
More information about the Mapguide_users
