[mapguide-users] metadata in a layer for wms-service
Bruce Dechant
bruce.dechant at autodesk.com
Mon Sep 18 13:46:26 EDT 2006
Axel,
After you added the WKT translations you need to stop your web service and using "Task Manager" ensure that there are no MapAgent.exe processes still running and then restart your web service. This information is cached and so your changes may not actually be read yet.
Bruce
_____
Sent: September 17, 2006 4:10 AM
Subject: [mapguide-users] metadata in a layer for wms-service
Hello list,
once again i need some help to deliver maps via wms .
With the friendly and very useful help of Andy and Bruce i got the right WKT Translation for EPSG:31467.
I added a <translate> command in the OgcWmsService.config.awd - and i hope found the correct place for it. Have a look at the attachment.
The properties of the layer to publish are populated in "bounds-field" with: <Bounds SRS="EPSG:31467" west="3556600" south="5374600" east="3557700" north="5375600"/>
The field for "extended metadata" in studio for the requested layer is empty.
The getmap-request looks like this:
http://localhost/mapguide/mapagent/mapagent.fcgi?REQUEST=GETMAP&SERVICE=WMS&VERSION=1.1.1&STYLE=DEFAULT&FORMAT=image/png&SRS=EPSG:31467&BBOX=3556600,5374600,3557700,5375600&WIDTH=200&HEIGHT=200&LAYERS=Test/Layer/Genehmigungsgrenze%202001
With this i don´t get an error-message anymore, but a map is also not displayed.
Gaia tells me within the Selected Layer Info:
Title: TEST WMS
Namespace:
Keywords:
LL BBox: (-180,-90;180,90)
BBox: (3556600,5374600;3557700,5375600)
Supported SRS:
EPSG:31467
EPSG:4326
The Log of Gaia is the following:
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidSRS">
The spatial reference system specified is not supported. (Found SRS=EPSG:4326)
</ServiceException>
</ServiceExceptionReport>
Error during HandlerWMS:AsyncReader
Source URL = http://entwicklung/mapguide/mapagent/mapagent.fcgi?
Layer name = Test/Layer/Genehmigungsgrenze 2001
CarbonTools.Core.Base.CarbonToolsException: Server responded with an error
at CarbonTools.Core.WMS.HandlerWMS.AsyncReader(IAsyncResult result)
Apparently EPSG:4326 wins against EPSG:31467. At least this is my impression.
Regards,
Axel
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060918/8811ee73/attachment.html
More information about the Mapguide_users
