[mapguide-users] Problems with MySQL
peter56
ibb.scigalla at arcor.de
Thu Sep 21 09:20:42 EDT 2006
Hi Adam,
my first testconnection to MySQL works. I'm using MySQL 5.0, the latest FDO
(downloaded during the last 4 weeks) and MG Studio from Autodesk. But I
tried it only with 5 points.
Regards - Peter
Adam Herbert wrote:
> Hi,
> Has anybody got FDO's using MySQL data sources working properly? I can
> get it to read the data but it is not selectable and it doesn't seem to
> recognise the geometry types properly.
> Thanks.
> Adam Herbert
> IT Manager
> AEM Solutions Pty Ltd
> PO Box 514, Toowoomba Q. 4350
> Phone: 07 4613 0455
> Cell: 0437 599 907
> Website: www.aemsaustralia.com.au <http://www.aemsaustralia.com.au>
> Important Disclaimer and Warning
> AEMS does not represent or warrant that any attached files are free from
> computer viruses or other defects. The attached files are provided, and
> may only be used, on the basis that the user assumes all responsibility
> for any loss, damage or consequences resulting directly or indirectly
> from use of the attached files. The liability of AEMS in any event is
> limited to either the re-supply of the attached files or the cost of
> having the attached files re-supplied.
> NOTE: The views expressed by the individual in this message do not
> necessarily reflect those of the organisation.
> AEMS is committed to protecting the privacy of individuals, and is bound
> by the principles of the Commonwealth Privacy Act (1988).
> The information contained in this message is confidential and may be
> legally privileged. The message is intended solely for the addressee(s).
> If you are not the intended recipient, you are hereby notified that any
> use, dissemination, or reproduction is strictly prohibited and may be
> unlawful. If you are not the intended recipient, please contact the
> sender by return e-mail and destroy all copies of the original message.
View this message in context: http://www.nabble.com/Problems-with-MySQL-tf2230264.html#a6427956
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide_users
